V70, no turbo boost, D5 engine, 163 hp
chriskross
Post26-03-2012, 20:20    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
Hi!
I'm experiencing a significant loss of power in my Volvo (error code: deviation in turbocharger pressure control). According to the diagnostic tool, no boost pressure is being generated.
The intercooler was covered in oil, but I couldn't detect any leaks.
The turbo's wastegate adjustment is easy to operate, and the exhaust values are quite good, so there's no soot.
I still need to check the vacuum adjustment.
Could a faulty intercooler be the reason why no boost pressure is being generated or can be generated?
A6 AFB
A6 BRE DPF
Translated on 14-07-2026, 21:23.
roorback
Karma: +1 / -2   Thank you, like it!
Post26-03-2012, 20:31    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
hey
ein volvofahrer... ich hatte einen D5 - da war ähnliches - und im prinzip "nur" der schlauch ab; das wäre aber zu einfach - oder ? icon_wink.gif
Hello.
Translated on 14-07-2026, 21:24.
chriskross
Post26-03-2012, 20:48    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
"Hi, it would be great if it's just a hose."
A6 AFB
A6 BRE DPF
roorback
Post26-03-2012, 20:50    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
Well, that would be easy to verify... but from my understanding, it's nothing unusual for the D5 series.
Translated on 14-07-2026, 21:25.
Post26-03-2012, 21:34    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
The intercooler was covered in oil, however, I couldn't detect any leaks.
Kann der Ladeluftkühler schuld sein das kein Ladedruck aufgebaut wird bzw. werden kann?
Yes, taking shortcuts makes you smarter icon_wink.gif.
chriskross
Post27-03-2012, 9:50    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
It was due to the vacuum system, which lost pressure through the front engine mount. icon_wink.gif This is controlled by vacuum in the Volvo.
A6 AFB
A6 BRE DPF
Translated on 14-07-2026, 21:26.
roorback
Post27-03-2012, 9:58    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
That's correct, yes. Great - I'm glad it was simple.
Post27-03-2012, 11:46    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
Thank you for the feedback! Nevertheless, the turbocharger system should be checked for leaks, because if it is sealed properly, no oil mist will leak out. icon_idea.gif
chriskross
Post27-03-2012, 12:23    Subject: V70, no turbo boost, D5 engine, 163 hp Quote
I will get back to you shortly. Thank you very much!
A6 AFB
A6 BRE DPF
Translated on 14-07-2026, 21:27.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intermittent lack of boost pressure, 1.8T AUM Gasoline Engine Technology
No new posts A4 1.8T AEB - No boost / power Gasoline Engine Technology
This topic is locked, you cannot edit or reply. AJM power loss, not turbo pressure Diesel Engine Technology
No new posts AJM Problem kein Ladedruck ? Diesel Engine Technology
