DIY Adapter: Build Your Own Adapter
haggis.dhi
Post04-08-2003, 14:28    Subject: DIY Adapter: Build Your Own Adapter Quote
Hey everyone!
I've now decided to build my own adapter so that my constant 'searching for the needle in a haystack' at night new_shocked.gif (hopefully) comes to an end.
I have a GIII model year 1994 with a 1Z engine.
'Does anyone have any experience with whether the 'enhanced standard circuit' will work effectively? I mean, will it work with my car specifically, or are there generally any compatibility issues between adapter types and TDI engines?'
Also, I also need the parts. I can get the electrical components at CONRAD around the corner, but where can I get the VAG connector (the wide one, the ODB? icon_redface.gif)?
Jaja, viele Fragen! Thank you in advance!
Andreas.
Translated on 29-09-2026, 9:30.
Albrecht
Post04-08-2003, 15:53    Subject: DIY Adapter: Build Your Own Adapter Quote
You don't necessarily need the OBD connector. A few crimped cable ends will also work. If you absolutely want one, check eBay; I believe they are sometimes auctioned off for around 15 euros.
Regarding the other questions, I can't provide any reliable information.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
Translated on 29-09-2026, 9:31.
Post04-08-2003, 16:16    Subject: DIY Adapter: Build Your Own Adapter Quote
haggis.dhi wrote:
I have a GIII, model year 1994, with a 1Z engine.
Does anyone have any experience with whether the "enhanced standard circuit" will work successfully? I mean, will it work with my car, or are there generally any compatibility issues between adapter and TDI types?
Hi Andreas,
If you're referring to version 2.4, it generally runs quite reliably based on previous experiences, provided that the PC and software configuration are compatible.
However, some 1Z models can be problematic, and this issue may not be resolved by using a different adapter (or only in rare, fortunate cases). A more reliable solution seems to be adjusting the VAGCOM settings -> Diagnostics, section "VAGCOM Bugs."
"A '1Z-favorite adapter' hasn't emerged yet, as far as I know."
Translated on 29-09-2026, 9:33.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Diagnostic Tools: Store-Bought vs. DIY? Diesel Engine Technology
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts Adapter Diesel Engine Technology
No new posts USB K-Line Adapter: Buy Now! Diesel Engine Technology
