Car Wiring (09) & Comfort Systems (46) - Solved
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Martin L.
Post03-04-2012, 18:43    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Quote
Hello everyone,
I was just about to check out what features I can enable by coding on my new Alhambra.
Unfortunately, I was unable to establish communication with the vehicle's network and comfort system.
Do I have a problem with the vehicle, or with VCDS?
See Autoscan.
Thank you very much.
Martin.
Log-NU R 1976-VSSZZZ7NZCV510123-858.txt
 File name:  Log-NU R 1976-VSSZZZ7NZCV510123-858.txt
 File size:  12.54 KB
 Downloaded:  2019 times
Translated on 16-10-2026, 9:22.
Post03-04-2012, 19:08    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Quote
2009+ Golf/GTI/Jetta and similar models, no communication with control unit address 46 or 09.
Many vehicles from 2009 onwards integrate the addresses and functions of the comfort control unit (address 46) into the body control module (address 09). Therefore, access and configuration are performed via the body control module. Note that the vehicle must be unlocked and locked, and the ignition must be ON in order to gain access. This behavior is therefore normal.
Translated on 16-10-2026, 9:23.
Martin L.
Post03-04-2012, 19:15    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Quote
Oh, thank you very much!
I had the ignition on, but the car was locked!
Okay, I'll test it again tomorrow.
Translated on 16-10-2026, 9:24.
Post03-04-2012, 19:17    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Translating...
[Translating...]
Post03-04-2012, 19:51    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Quote
Really?
BCMs become dense when you increase them?
I have to test it sometime on Monday.
Martin L.
Post05-04-2012, 9:10    Subject: Car Wiring (09) & Comfort Systems (46) - Solved Quote
Thank you, the problem is solved.
Actually, one cannot draw that conclusion.
Translated on 16-10-2026, 9:25.
No new posts Document Touran, Error in Comfort System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf3 pulls to the left (SOLVED) General Tips
This topic is locked, you cannot edit or reply. Touran: Intermittent P01314 Error - Solved Diesel Engine Technology
No new posts Golf 4 Interior Light - Comfort System Upload
No new posts VCDS: Comfort System Module 46 - Version 20.4.2 On-Board Diagnostics (OBD)
No new posts Central Control Unit Upgrade for Comfort Systems (J393) Electrical Systems, Vehicle Electronics, Multimedia
