vrsechs
Registered VCDS User
02-04-2012, 22:05 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
Hello everyone in the forum community,
Unfortunately, I couldn't find the error in the search function as I usually do, so I'm writing to you about it.
"The problem car is a 2006 Sharan BRT with 265,000 km. I had the DPF (Diesel Particulate Filter) cleaned about 15,000 km ago."
The engine runs smoothly when it's cold, and the idle is normal, as is typical for a PD engine.
The problem only occurs when the engine is warm, approximately from 60 degrees Celsius.
Then the following happens: You'll experience significant jolting or shaking when accelerating or driving at a constant speed, starting around 3rd gear. The engine runs from approximately 1100 RPM to around 2600 RPM, and then it pulls strongly all the way to the end (I didn't dare to go to its maximum speed).
The idle speed control shows good values when the engine is cold, within a range of plus or minus 1. However, the situation is different when the engine is warm. When the engine misfires, the idle becomes very rough, and the idle speed control goes to its maximum setting (level 3). Cylinder partially filled to maximum pressure +2.99mg/H.
| Description: |
 Download |
| File name: |
LOG-01-001-xxx-xxx-sharan.CSV |
| File size: |
5.88 KB |
| Downloaded: |
925 times |
| Description: |
 Download |
| File name: |
LOG-01-011-003-067-sharan.CSV |
| File size: |
5.14 KB |
| Downloaded: |
702 times |
| Description: |
 Download |
| File name: |
LOG-01-013-xxx-xxx.CSV |
| File size: |
36.03 KB |
| Downloaded: |
669 times |
| Description: |
 Download |
| File name: |
LOG-01-013-007-067-sharan-warm.CSV |
| File size: |
11.56 KB |
| Downloaded: |
760 times |
| Description: |
 Download |
| File name: |
LOG-01-013-004-005sharan-kalt.CSV |
| File size: |
20.87 KB |
| Downloaded: |
744 times |
Joined: 04/12/2002 Posts: 18115 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
02-04-2012, 22:22 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
I removed the bottom part of the post because it wasn't relevant, and I didn't feel like correcting all the errors. Please put in a little more effort.
A typical cause for this type of "error" would be assembly errors in the PD unit. Please replace the gasket, preferably with a new one, and reassemble with cleaned and inspected sealing surfaces, ensuring proper alignment and adjustment.
Profile PM WWW Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
03-04-2012, 1:05 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
In addition, I would like to expand and swap a second PD (presumably referring to a "power distribution" or similar component). If the error persists, at least we can see whether it's moving along with the system or not.
3B5 AJM
vrsechs
03-04-2012, 17:16 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
Hey, so, I probably shouldn't become an author  . But it's good that you're taking care of things and keeping them organized.
Okay, so I'm going to have the PDEs (presumably referring to something specific in this context) expanded and cleaned, and also have a cross-exchange performed.
Can we continue running the PDEs like this, or should we switch them back after this? Greetings.
BM Profi-Schrauber
03-04-2012, 18:21 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation. Don't forget to adjust the basic settings of the PDs.
3B5 AJM
vrsechs
16-04-2012, 11:18 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
I've now had all the PDE components ultrasonically cleaned, replaced the seals, and performed the initial adjustment (which was easier than I thought). And everything is working properly again, just like it did on the first day. BIG THANK YOU.
16-04-2012, 12:33 Subject: Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm |
Thank you also for the feedback!
