Octavia_4x4 Schrauber
10-04-2012, 19:46 Subject: VW Golf IV: ESP/ABS error |
Today I scanned a Golf, and the following information appeared: The ESP (Electronic Stability Program) is apparently not working, as the warning light is illuminated.
What I'm interested in: the communication error from the brake control module (STG) - could this be related to the defective G200 sensor from the ESP system? Apparently, the G200 has internal solder joint failures, so I'll have to painstakingly remove it, solder the connections, and secure it, as I've done many times before with Golf IVs.
Quote: | Tuesday, April 10, 2012, 17:06:30:55819
VCDS Version: RKS 11.11.1
Data as of: 20120106.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 1J - VW Golf/Bora IV
Mileage: 147,570 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\036-906-032-AXP.lbl
Part number: 036 906 032 P.
Part number: ME7.5.10 3695
Encoding: 00031
Operating number: WSC 00046
VCID: 1D347CE197AAEE1
No error codes found.
Readiness: 1110 0101
Address 03: Brakes Label file: RKS\1C0-907-37x-ESP-F.lbl
Part number: 1C0 907 379 E.
Part: ESP FRONT MK60 0104
Encoding: 0011266
Operating number: WSC 00046 615 1234567
VCID: 2C52A1258C10179
"1 error found:"
01423 - Lateral acceleration sensor (G200)
012 - Electrical fault in the circuit.
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 A
Part number: 27 AIRBAG VW51 01 0010
Encoding: 12855
Operating number: WSC 45420
VCID: 224E4F1DAED4D19
"1 error found:"
01280 - Passenger airbag deactivated.
35-00 - -
Address 17: Combination Instrument
Label file: RKS\1J0-920-xx5-17.lbl
Part number: 1J0 920 805.
Component: COMBINATION INSTRUMENT + TRIP COMPUTER. BOO V05.
Encoding: 01111
VCID: E3C08A19714E181
Subsystem 1 - Part number: Ident
Part number: WEGFAHRS.:VWZ6Z0A3116685
Identification Number: VWZ6Z0A3116685
"1 error found:"
01316 - Brake control unit.
49-10 - No communication - Intermittent.
Address 19: CAN-Gateway Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: F0EAF555B0B8B39
"1 error found:"
End
Furthermore, it's interesting to know: can the deactivated airbag be easily reactivated via VCDS through the channels? Since the airbag light is blinking, which correctly indicates a deactivated passenger airbag, I don't think a resistor plug is installed. The car does not have a key switch.
Greetings.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
10-04-2012, 22:41 Subject: VW Golf IV: ESP/ABS error |
The G200 actually only has 3 connection cables to the STG (System Transfer Gateway).
The G85, on the other hand, is connected to the CAN bus, but based on your statement, I suspect that the version with separate G200 and G85 units is still installed.
The communication problem could also be caused by a faulty ground strap located at the front, underneath the battery holder.
This tends to corrode on the Golf 4, so it might need to be replaced.
The statements are subject to change, as I am not 100% certain.
Best regards, Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
11-04-2012, 18:14 Subject: VW Golf IV: ESP/ABS error |
Yes, that's correct. He separated both sensors, and the smaller box is the G200. And on passatplus.de, you can find instructions on how to resolder it - I will definitely try that.
I'm familiar with the mass band problem - I just hadn't thought of it. That sounds good, I'll look into it.
Greetings.
Georg.
18-04-2012, 20:01 Subject: VW Golf IV: ESP/ABS error |
Is there anything new here? Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
22-04-2012, 16:05 Subject: VW Golf IV: ESP/ABS error |
Oh, I completely forgot, the G200 is working perfectly again after the reflow process. The other errors haven't reappeared, so I haven't taken any action for now.
22-04-2012, 16:50 Subject: VW Golf IV: ESP/ABS error |
Okay, so the connector pins on the G200 circuit board (mounted on the steering column) were resoldered after removing the potting compound.
Thank you for the feedback!
Profile PM WWW Garage |
22-04-2012, 18:01 Subject: VW Golf IV: ESP/ABS error |
However, some caution is needed when disassembling the G200.
The component soldered onto the circuit board tends to get stuck in the potting compound, so it is essential to pay close attention to the position of the circuit board when reassembling.
Greetings. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
