Audi A4 B6 Rear Door Won't Unlock (Solution)
Post25-04-2012, 16:29    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
A colleague is having a problem with his A4 B6; one of the rear doors no longer unlocks with the central locking system. Is there perhaps a trick to open the door from the inside without causing any damage, in order to remove the trim for repair?
Translated on 18-08-2026, 18:08.
Post25-04-2012, 17:11    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Let's try one more time to see if we can trick the lock again.
Possibly disconnect the battery for 1 minute - has that helped before?
I would try to work around it first, before things become unpleasant.
Removing the disguise will be difficult, if not impossible.
because it also serves as a seal at Audi, so it's positioned in front of the door rubber, not between them.
Do you even know how to normally remove the trim?
If no ---> Vehicle data?
Translated on 18-08-2026, 18:09.
Post25-04-2012, 18:20    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Okay, I'll pass that information along about disconnecting the battery.
He generally has access to the Audi repair manuals.
Translated on 18-08-2026, 18:10.
pax
Avatar-pax
2000 Volkswagen Passat
Post25-04-2012, 20:07    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
The rear door no longer unlocks using the central locking system
It's probably not possible to pull the interior door handle twice on a B6 model.
Bye.
peace
Translated on 18-08-2026, 18:11.
Post25-04-2012, 20:27    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
pax wrote:
No longer unlocks a rear door via central locking
Bye.
peace
He had already tried that, unsuccessfully.
Translated on 18-08-2026, 18:12.
Post25-04-2012, 21:52    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
So, don't open the lock.
That's a bad situation. Let's try a little bit and hope the engine starts again.
Translated on 18-08-2026, 18:13.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post26-04-2012, 20:13    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Is it possible to remove the door handle separately here?
It's difficult to compare, but I've experienced this issue multiple times with the Actros truck. In those cases, I was able to "bypass" the lock by using a small gap and a long wire.
Translated on 18-08-2026, 18:14.
Post26-04-2012, 20:19    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
It was difficult to compare, but it had already been on the Actros
several times.
Okay. If you're unlucky, the lock might be encapsulated within the mechanism.
Nothing will get through from the outside.
Post26-04-2012, 20:46    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Unfortunately, I haven't heard anything new from him yet...
Translated on 18-08-2026, 18:15.
michiglaser
2007 Audi A4 Avant
Post02-05-2012, 22:40    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Otherwise, it should be mentioned that the door panels for the B6 are relatively inexpensive to obtain from 3-2-1 icon_wink.gif.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post02-05-2012, 22:46    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
Thank you everyone, and also thank you for the tip about the book.
Disconnecting the battery, by the way, didn't help icon_sad.gif.
It looks like the dealer will be taking care of it. Luckily, he still has a warranty on the used car. I'll let you know if there's any news.
Translated on 18-08-2026, 18:16.
Post02-05-2012, 23:38    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
michiglaser wrote:
Otherwise, it should be mentioned that the door panels for the B6 are relatively inexpensive at 3-2-1 icon_wink.gif
However, as Autoservice already mentioned, with Audi, you always have this frame structure included.
I don't know how it looks in the back of the B6, but in all the Audis I've worked on so far, destroying just the door panel wouldn't really achieve much because you have to remove the entire frame. icon_sad.gif
Translated on 18-08-2026, 18:17.
Post20-05-2012, 20:59    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
The door is now open.
You need to pull on the levers both inside and outside simultaneously while operating the control panel. If anyone else is experiencing this problem...
Translated on 18-08-2026, 18:18.
Post21-05-2012, 16:55    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
You need to pull the levers both inside and outside simultaneously while operating the control panel. If anyone else encounters this problem...
Thank you for the feedback!
Post21-05-2012, 19:03    Subject: Audi A4 B6 Rear Door Won't Unlock Quote
In addition, I learned today that the door has been working normally again since this "reset" icon_smile.gif.
Translated on 18-08-2026, 18:19.
Ratings - Audi A4 B6 Rear Door Won't Unlock
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG 2003, trunk won't unlock, KSG flooded Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A6 Rear Door Handle - Replacement Transmission, Chassis, Body & Interior
No new posts Passat 3BG: Rear Door Unlock Problem? Transmission, Chassis, Body & Interior
No new posts Replacing rear brake discs on a G3 - difficult? Transmission, Chassis, Body & Interior
