MicroCAN: Golf 6 - Control Units Not Responding
gugiboy
Post21-05-2012, 14:29    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
Good day.
I received the MicroCan a few days ago. I have VCDS RKS version 11.11.3 installed on my computer (Win7), which I want to use to perform coding modifications on my Golf 6 GTI.
Problem:
Some control units respond, while others do not (see Autoscan).
"My primary concern would be access to the '17-in-1 instrument'."
Solution behavior so far:
Locked, attempted to completely unlock the vehicle, ignition key in the first, second, or third position, while the engine was running, disconnected the battery and waited for 10 minutes - all without success.
"Since today, another error code has appeared under 08-Climate/Heating, but I am unable to read it. In this case as well, the error message "Control unit not responding" appears."
Where could the dog be buried here?
Thank you in advance and best regards.
Thomas.
PS: I've already used the search function and checked other forums (like the vagcom wiki), etc. Before ordering the MicroCAN, I checked the website of Kaufmann Automotive GmbH and found information stating that the Golf 6 is compatible with the MicroCAN.
VCDS Version: RKS 11.11.3
Data as of: 20120406.
Monday, May 21, 2012, 2:50:36:61229
Vehicle type: 7N0
Scan: 01 03 08 09 10 14 15 16 17 19 20 25 2E 37 42 44 46 52 55 56
62 72
Vehicle Identification Number: WVWZZZ1KZBW17XXXX
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating -- Status: Error 0010.
09-Onboard network -- Status: OK 0000
10-Parking assist 2 -- Status: OK 0000
14-Wheel suspension -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine (CCZ)
Label file: 06J-907-115-CCZ.clb
Part number SW: 5K0 907 115, HW: 1K0 907 115 AA.
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Encoding: 0403000C18070160
Operating number: WSC 00191 264 15243
VCID: E7F26F33D676751
No error codes found.
Readiness: 0010 0100
Address 03: Brakes (J104)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BE, HW: 1K0 907 379 BE.
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Encoding: 143B600D092900FC281006E7901D0041350800
Operating number: WSC 01357 011 00200
VCID: 76CCB277C1DC1C9
Address 08: Climate/Heating.
unavailable
Address 09: Body Control (J519)
Label file: RKS\1K0-937-08x-09.clb
Part number SW: 1K0 937 087 J HW: 1K0 937 087 J
Part: BCM PQ35 H 103 0615
Revision: 00103 AD
Encoding: 4E180A3AE833F3C040880088310009E4437D008853218D20E48000240040
VCID: 38507C4F8B48AA9
Subsystem 1 - Part number: 5K1 955 119
Label file: RKS\1KX-955-119.CLB
Component: Wiper 26111 26 0512
Encoding: 009795
Subsystem 2 - Part number: 1K0 955 559 AH. Label file: RKS\1K0-955-559-AG.CLB.
Component: RLS 271110 05 54 0403
Encoding: 0430AD
Subsystem 3 - Part number: 1K8 951 171.
Component: DWA sensor 00 001 0104.
Subsystem 4 - Part number: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Address 10: Parking Assist 2 (J446)
Label file: RKS\3C8-919-475.clb
Part number SW: 5K0 919 475 E, HW: 5K0 919 475 E.
Part: PARKING ASSIST 8K H01 0012
Revision: -------- Serial Number: 1259103191XXXX
Encoding: 108003
Address 14: Wheel Damping (J250)
Label file: RKS\3C0-907-376.clb
Part number SW: 3C0 907 376 A, HW: 3C0 907 376
Component: SOUND DAMPENING MATERIAL H07 0071
Revision: 00000000 Serial number: 2311100161XXXX
Coding: 000180
VCID: 2772AF3356F6351
Address 15: Airbag (J234)
Label file: 5K0-959-655.clb
Part number SW: 5C0 959 655 B, HW: 5C0 959 655 B.
Part: Airbag VW10 013 0613
Serial number: 003G5R01XXXX
Coding: 00003834
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3146416B60327B1
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME3348155AXXXX
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Passenger Side, H01.
Serial number: 3582MSME272C065XXXX
Crash sensor for rear side airbag, driver's side.
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME3A507610XXXX
Crash sensor for rear side airbag, passenger side.
Component: S. Sensor, Front, Right. --- ----
Serial number: 3522QSME06467667XXXX
Address 16: Steering wheel.
unavailable
Address 17: Combination instrument.
unavailable
Address 19: CAN-Gateway (J533)
Label file: 7N0-907-530-V2.clb
Part number SW: 7N0 907 530 C, HW: 1K0 907 951.
Component: J533 Gateway H37 0614.
Revision: H37 Serial number: 021210F200XXXX
Encoding: 350002
VCID: 3040446F6338729
Address 20: High Beam Assist (J844)
Label file: RKS\8K0-857-511.clb
Part number SW: 5K0 857 511 B, HW: 8P0 857 511 C.
Component: FLA H04 0006
Revision: AA001002
Encoding: 02018B6B74745D545420363E00
VCID: 2D7E5D1B740A1F1
Address 25: Immobilizer.
unavailable
Address 2E: Media Player 3 (J650)
Label file: RKS\5N0-035-342.lbl
Part number SW: 5N0 035 342 D. Part number HW: 5N0 035 342 D.
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial Number: 766897XXXX
Encoding: 010000
VCID: 2870AC0F5BE83A9
Address 37: Navigation (J0506)
Label file: RKS\1T0-035-680.clb
Part number SW: 1T0 035 680 C, HW: 1T0 035 680 C.
Component: RNS-MID H42 2720
Revision: AB001001 Serial Number: VWZ6Z7K833XXXX
Encoding: 040004020400009000
ASAM Dataset: ------------------------- ------
VCID: 2E7C5A17790C649
Address 42: Door electric, driver's side.
Label file: RKS\1K0-959-701-MAX3.lbl
Part number SW: 5K0 959 701 E, HW: 5K0 959 701 E.
Component: Door seal 009 2151
Coding: 0004278
VCID: 3448487F57204E9
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K0 909 144 J
Component: EPS_ZFLS, Size 184, Part Number 3001.
Revision: 00H17000
VCID: 3146416BA8327B1
Address 52: Door electronics, passenger side.
Label file: RKS\1K0-959-702-MAX3.lbl
Part number SW: 5K0 959 702 C. Hardware: 5K0 959 702 C.
Component: Door seal 009 2119
Encoding: 0004534
VCID: 334A4B63522E491
Address 55: Headlight range adjustment.
Label file: RKS\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 C. Hardware: 5M0 907 357 C.
Component: AFS Control Unit 0148
Revision: 00H04000 Serial Number:
Encoding: 1444956
Subsystem 1 - Part number: 7L6 941 329 B
Component: AFS-Lst. Module l 0004
Encoding: 00000022
Subsystem 2 - Part number: 7L6 941 329 B
Component: AFS-Lst. module r 0004
Encoding: 00000022
Address 56: Radio (J0506) Label file: RKS\1T0-035-680.clb
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN3.lbl
Part number SW: 5K0 959 703 D, HW: 5K0 959 703 D.
Component: Door seal 007 2101
Encoding: 0000144
Operating number: WSC 01357 011 1012552
VCID: 354E757B5C5A571
Address 72: Door electric strike, high, right.
Label file: RKS\1K0-959-704-GEN3.lbl
Part number SW: 5K0 959 704 D, HW: 5K0 959 704 D.
Encoding: 0000144
VCID: 364C7277415C5C9
End.
 Fehlermeldung beim einloggen auf das Kombiinstrument
 File size:  731.96 KB
 Viewed:  6614 times
 Rückmeldung VCDS/Programmeinstellungen/Test
 File size:  222.25 KB
 Viewed:  4905 times
Golf 6 GTI 2011, RNS510
Translated on 24-10-2026, 0:45.
Post21-05-2012, 15:13    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
Does the instrument cluster function properly? The vehicle type 7N is a VW Sharan, and NOT a Golf 6!
How does the "Type 7N" appear in the scan? Have any combination instruments or other control units (CAN gateway) been replaced, modified, etc.?
Translated on 24-10-2026, 1:13.
gugiboy
Post21-05-2012, 15:35    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
To the best of my knowledge, the instrument cluster is functioning correctly.
He always returns this vehicle type (7N0): both when using "Atom. Erkenn.(nur CAN)" and when using "5K - Golf/Jetta VI".
No control units (hardware) were replaced.
Do these control units perhaps need to be unlocked (or do you need to log in with a password)?
Thank you & Best regards.
Thomas.
Translated on 24-10-2026, 1:14.
Post21-05-2012, 15:47    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
no.
It seems that the "7N" type is actually "normal," but I find it somewhat unattractive.
I'll keep looking.
Translated on 24-10-2026, 1:15.
gugiboy
Post21-05-2012, 15:56    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
I've discovered the problem:
The USB 3 port on my HP laptop seems to be the source of the problem.
When switching to a USB 2.0 port, the other control units suddenly become available as well.
It's strange that only a portion of the group didn't communicate properly?!
Thank you so much for the super-fast help.
Thomas.
Translated on 24-10-2026, 1:16.
Post21-05-2012, 16:00    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
That's quite a peculiar solution, I wouldn't have expected that.
Thank you for the feedback!
Post22-05-2012, 8:09    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
Hi.
I seem to recall that Windows installs the drivers for each port individually.
If that's the case, or if it was the situation in a specific Windows version, it's possible that when you change the port, the already known drivers will be reinstalled and then function correctly.
However, that's just a reconstruction based on very vague memories.
Translated on 24-10-2026, 1:17.
gugiboy
Post22-05-2012, 8:44    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
The device has another USB 3.0 port (which has not been used by VCDS before) - the issue might not occur through this port after the driver has been freshly installed?
More updates later.
Thomas.
Translated on 24-10-2026, 1:18.
Post22-05-2012, 8:48    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
gugiboy wrote:
More updates later.
Is the keyboard also connected via USB?
Then you have a massive USB problem icon_lol.gif.
gugiboy
Post22-05-2012, 11:55    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
Yes, no, that's obvious, it's due to a (too) short coffee break icon_razz.gif.
I tested all the ports on my HP notebook (8560w) using VCDS, and the reaction was as follows:
Port 1 [UBS2.0]: Full functionality.
Port 2 [UBS2.0]: Full functionality.
Port 3 [UBS2.0 & ESATA]: Full functionality.
Port 4 [UBS3.0]: Limited functionality with certain control units.
Port 5 [UBS3.0]: Limited functionality with certain control units.
Could someone else please test this to rule out or confirm a recurring issue with the USB 3.0 ports?
Thomas.
Translated on 24-10-2026, 1:20.
Post23-05-2012, 13:45    Subject: MicroCAN: Golf 6 - Control Units Not Responding Quote
@gugiboyViewing profile: gugiboy: For problem-solving, the following would be interesting:
- What is the computer configuration? Please specify the Windows version, service pack, computer model, and USB 3.0 chipset.
- What does VCDS display when you plug the diagnostic cable into the port where it doesn't work and click "Test" in the program settings? This will show the driver version. Please send me a Screenshot.
- What will be displayed as shown above when it's plugged into a port that works?
Translated on 24-10-2026, 1:21.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control units not responding, Audi A6 2.5 TDI (solved) On-Board Diagnostics (OBD)
No new posts Golf 3 TDI GT: Common Electronics Problems On-Board Diagnostics (OBD)
No new posts ECU Not Available: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts A7 4K: Control units unreachable & data bus errors On-Board Diagnostics (OBD)
