Golf 4 AJM Engine: Running on 3 Cylinders Only
kuestenkuddel
Post21-06-2012, 23:50    Subject: Golf 4 AJM Engine: Running on 3 Cylinders Only Quote
Hi everyone,
I just installed a new turbocharger in a Golf. I drained about 1 liter of engine oil from the intercooler and ran the engine until the blue smoke stopped.
Everything seems to be fine now, there's no more exhaust smoke, but one cylinder isn't firing correctly.
How do I find the 'dead pot'?
Idle speed regulation is normal: 1. Cylinder slightly high + approximately 0.5. 2. Cylinder slightly low - 0.5.
Does anyone have any ideas?
Best regards, Kurt.
Translated on 19-08-2026, 19:56.
DieselBär30x
Avatar-DieselBär30x
Post22-06-2012, 0:06    Subject: Golf 4 AJM Engine: Running on 3 Cylinders Only Quote
First and foremost, it would be extremely helpful if you could tell us about the specific error message or the exact reason for the ATL replacement.
Assuming that with 1 liter of oil in the transmission, the old unit failed and debris/fragments passed through the transmission line.
Did the engine then run without oil?
How would you determine that the AJM is running on 3 pots when the LLRR seems to be fine? ...that contradicts itself somewhat icon_wink.gif.
Please upload a MWB's 13/18/23 reading at cold and warm idle first.
(Please also add a VCDS license to the profile, as no further support can be provided without it!)
Best regards from Munich!
Translated on 19-08-2026, 19:58.
kuestenkuddel
Post22-06-2012, 21:14    Subject: Golf 4 AJM Engine: Running on 3 Cylinders Only Quote
Hi DieselBear.
Assuming that with 1 liter of oil in the transmission, the old unit failed and debris/fragments were circulating through the transmission line.
The Golf started smoking heavily and lost power, so it was brought to me for repair.
The turbine and compressor wheels can be moved back and forth as if the rotor bearings are missing.
The oil was still visible on the dipstick, well below the minimum mark.
How would you determine that the AJM is running on 3 pots, even if the LLRR seems to be working correctly? ...that contradicts itself somewhat icon_wink.gif.
Any skilled mechanic can recognize it by the sound and feel.
Please translate the following text from German to English. Provide ONLY the translation, no explanations.
(Also, please add a VCDS license to my profile, as otherwise, no further support is ALLOWED!)
'I'm not familiar with those MWB numbers (13/18/23). I use a Gutmann MegaMax 55, which allows me to access parameters. Which parameters would you like to know?'
Best regards from Hamburg.
Translated on 19-08-2026, 20:02.
DieselBär30x
Avatar-DieselBär30x
Post23-06-2012, 0:02    Subject: Golf 4 AJM Engine: Running on 3 Cylinders Only Quote
Okay, there was still some oil in the engine, but the oil pressure was definitely gone.
The question primarily focused on the mechanical condition of the air intake manifold (specifically, the side where air is drawn in).
Based on your description, I assume that significant fragments and abrasive particles entered the intake air path and consequently reached the AJM (?).
Regarding the "3-Pot Run":
Every skilled mechanic can recognize it by the sound and the feel.
icon_arrow.gif Exactly what I was looking for, I've been searching for ages, LLRR values are OK, but the ZMS was defective. icon_exclaim.gif
Unfortunately, I'm not familiar with Gutmann testers and therefore cannot assist you with their operation or interpretation of results.
In summary, it involves the simultaneous recording of values for idle speed control, power delivery engine (PDE) states, and variations in PDE switching times.
With VCDS, the mandatory measurement blocks would be numbers 13, 18, and 23.
Support for users without a valid VCDS or Bavarian (whatever-BMW-thingy) license is no longer provided, especially when an analysis in that direction is required. (Sorry.)
Therefore, if I observe subtle LLRR patterns, I would tend to look for explanations in a different direction – with or without talent/intuition icon_wink.gif.
Otherwise, check for debris in the low-pressure (LL) circuit. Then REPLACE the LL cooler!!!! *important* And use an endoscope to inspect the valves, piston rings (PDEs), pistons, etc., inside the engine for any consequential damage.
Translated on 19-08-2026, 20:06.
kuestenkuddel
Post26-06-2012, 22:17    Subject: Golf 4 AJM Engine: Running on 3 Cylinders Only Quote
Hi DBear,
Today I found half an hour to check my engine's misfire issue (likely a three-cylinder misfire). I created five individual jumper cables and connected them one by one between the PDE connector to diagnose which cylinder is causing the problem.
All 4 cylinders are reacting uniformly ('icon_eek.gif').
Then I probably need to look at the clutch and the dual-mass flywheel next icon_sad.gif.
Best regards, Kurt.
Translated on 19-08-2026, 20:09.
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASZ Golf 4: Speed Limiter? Only 180 km/h? On-Board Diagnostics (OBD)
No new posts Golf GTD: High Fuel Consumption, Poor Performance Diesel Engine Technology
No new posts Golf III 1,9 TDI läuft nicht mit anderem Steuergerät? On-Board Diagnostics (OBD)
No new posts Check Golf 4 VR 5 AGZ catalytic converter, engine running... Gasoline Engine Technology
