Motorfragen zum ACV, im T4 (GELÖST) | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Karma: +590 / -0   Thank you, like it!
Post04-07-2012, 0:00    Subject: Quote
Autoservice wrote:
Have you ever stripped a screw before?
Given the length, one might think that a rotating rod is being used. icon_wink.gif
Hi!
No, I've never refused a contract extension before.
"But the tool here is 3/4", made by Facom and Gedore, and it was also at its breaking point."
I marked the screw head with a colored dot and then turned it until I reached 180 degrees.
That really cost a lot of money.
but I'd say it's better than any other dodgy repair shop.
It's just tightened with a 1/2" wrench until it's snug, and that's good enough.
I'm actually quite relieved that someone wrote in this forum and told me that the screw needs to be tightened so brutally.
Otherwise, I might have just mumbled it.
Translated on 21-07-2026, 9:16.
roorback
Karma: +1 / -2   Thank you, like it!
Post04-07-2012, 8:42    Subject: Quote
Hi.
The construction is already okay!
We were two people, and we had also extended the lifting platform. The car was raised to a height of 2.2 meters on the platform – I was already worried that the car would fall off.
Ultimately, it works out - I was even a little bit happy about icon_wink.gif.
Great – another 5-cylinder engine saved!
Translated on 21-07-2026, 9:18.
No new posts Golf3 pulls to the left (SOLVED) General Tips
This topic is locked, you cannot edit or reply. Synchronization angle 16V PD Germany (SOLVED) On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Understanding Question N75 (SOLVED) Diesel Engine Technology
This topic is locked, you cannot edit or reply. HDi Engine Performance Issues (Solved) Diesel Engine Technology
This topic is locked, you cannot edit or reply. Warm-start problem of a different kind (SOLVED) Diesel Engine Technology
