Performance boost with auxiliary power module?
cz26m
Post15-08-2003, 14:20    Subject: Performance boost with auxiliary power module? Quote
hi
I'm quite new here and I have a question, maybe you can help me.
I have an AFN engine with 110 horsepower and 140,000 km on the odometer. I bought an auxiliary control module for the fuel injection pump, and now it's smoking excessively when I give it full throttle. It's about 10 km/h faster, so you can definitely feel the difference.
I read about '10-cent tuning' and adjusted the resistor for the turbocharger's pressure sensor in the control module. Now it doesn't smoke as much, and it seems to have gained a little more power.
Do these modules that are used with the VP37 also increase boost pressure, or do they only change the amount of fuel? Because by changing the resistor, the turbo is now producing 0.2 bar more pressure. I don't want the module to be increasing the boost pressure and causing the turbocharger to fail.
What is the original boost pressure, and where can I measure it? Okay, that was a lot of questions. I would appreciate any answers you can provide.
look, Chris.
Translated on 16-08-2026, 5:42.
Michael II
Post15-08-2003, 14:47    Subject: Performance boost with auxiliary power module? Quote
For all your answers, please use the search function. Everything has been discussed multiple times before.
You can find the target values for your motor in the technical articles.
Tschüss
Michael II
Translated on 16-08-2026, 5:44.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis 12.2000, Brummgeräusche durch Freispreche... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD (ARL) Engine Tuning: Performance Boost Diesel Engine Technology
No new posts AGR durch ALH ersetzbar? Diesel Engine Technology
No new posts TDI-Kat-Nachrüstung durch VAG? Diesel Engine Technology
No new posts VAG-COM: Check NW/KW Timing on PD Engine On-Board Diagnostics (OBD)
