320d: Low Power? Boost Pressure Ratio Explained (Solved)
Blackfrosch
Post18-06-2012, 20:01    Subject: 320d: Low Power? Boost Pressure Ratio Explained (Solved) Quote
Hello everyone,
A 2009 320d with 177 horsepower is experiencing a lack of power.
The car can barely reach a speed of 210 km/h on the speedometer.
Since the Bavarian Technik Tool from the local workshop can no longer retrieve any data (since BMW performed a complete update of the control units).
I was left with only the VCDS.
Notably, the air mass does not increase linearly even with a constant LD pressure.
Since the g/s unit seemed strange to me as an EDC15 user, I created a log while the engine was idling, which confirmed my suspicion.
The LMM (likely referring to a mass flow meter) has already been replaced, but it resulted in no change. Removing the LMM also does not lead to any noticeable improvement.
The air filter was removed by some leaves and cleaned, which increased the maximum airflow from 120g/s to 127g/s. According to the previous owner, the filter has been installed for 20,000 km. A new one is already on its way.
Unfortunately, I am unable to read the turbocharger boost pressure control valve (VTG) data. I suspect a blockage/restriction or an open EGR valve.
I am grateful for any help or ideas.
"Hello Blackfrosch"
LOG-320d-LuMa_LD_3GangVOLLGAS.xls
 File name:  LOG-320d-LuMa_LD_3GangVOLLGAS.xls
 File size:  14.5 KB
 Downloaded:  454 times
LOG-320d-LuMa_LD_Leerlauf.xls
 File name:  LOG-320d-LuMa_LD_Leerlauf.xls
 File size:  9 KB
 Downloaded:  466 times
Translated on 31-10-2026, 17:33.
Blackfrosch
Post22-06-2012, 12:39    Subject: 320d: Low Power? Boost Pressure Ratio Explained (Solved) Quote
In these two pictures:
http://de.bmwfans.info/parts/catalog/E91N/Touring/Europe/320d-N47/LHD/N/2009/february/browse/engine/intake_manifold_supercharg_air_duct_agr/
http://de.bmwfans.info/parts/catalog/E91N/Touring/Europe/320d-N47/LHD/N/2009/february/browse/engine/intake_manifold_agr_with_flap_control/
Here's the translation:
"This is the spot that, in my opinion, is causing problems. The question that I currently have is: how can the boost pressure be generated if there is a restriction before the boost pressure sensor? Therefore, the fresh air valve is likely not the cause?"
I would appreciate your valuable input.
"Hello Blackfrosch"
Translated on 31-10-2026, 17:35.
Post22-06-2012, 15:43    Subject: 320d: Low Power? Boost Pressure Ratio Explained (Solved) Quote
My input is that the links will eventually become dead, and therefore the thread will be useless.
Translated on 31-10-2026, 17:36.
Blackfrosch
Post24-07-2012, 7:48    Subject: 320d: Low Power? Boost Pressure Ratio Explained (Solved) Quote
A faulty exhaust gas temperature sensor caused the engine control unit to attempt to generate exhaust gas temperatures, likely by using methods such as swirl flaps and late fuel injection.
"Hello Blackfrosch"
Translated on 31-10-2026, 17:37.
Karma: +1100 / -0   Thank you, like it!
Post24-07-2012, 8:19    Subject: 320d: Low Power? Boost Pressure Ratio Explained (Solved) Quote
Thank you for the clarification!
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. HDi Engine Performance Issues (Solved) Diesel Engine Technology
No new posts Boost Issues Solved: Troubleshooting & Fixes On-Board Diagnostics (OBD)
No new posts Ratio of alternator speed to crankshaft speed with ribbed... Diesel Engine Technology
No new posts VTG Closure Fixes Temporary AVB Light Issues On-Board Diagnostics (OBD)
