23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
mullemaus
Post11-07-2012, 22:40    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Translating...
[Translating...]icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif icon_rolleyes.gif
Mc_Givertechnik
2010 Volkswagen T5
Post12-07-2012, 12:53    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
Hi everyone!
However, the theory and its calculations do not take all factors into account in this case. A T5 model, where the speedometer indicates 200 km/h, is likely only traveling at around 180 km/h. The display in the MFA (Multi-Function Display), which isn't entirely accurate, deviates increasingly from the actual speedometer readings.
I have the CS module from Canshack installed for MFA, and I can display the values directly via CAN, which is quite interesting. At 150 km/h on the speedometer, the CAN bus reports a speed of 136 km/h. Therefore, at a speedometer reading of 200 km/h, the actual speed is only a maximum of 180 km/h. Consequently, those 180 horsepower are not necessary icon_smile.gif.
I'm going to bring a GPS device with me and then see what information it provides. GPS isn't 100% accurate either, but it's certainly more precise.
Greetings,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 15-10-2026, 18:39.
chris11
Karma: +3 / -1   Thank you, like it!
Post12-07-2012, 15:25    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
Here.
http://www.autobild.de/artikel/vw-t5-multivan-2.5-tdi-4motion-43655.html
Here are some specifications for the T5 with different engine options.
If you can drive with GPS for a few minutes without interruption, it will become very accurate.
As a general rule of thumb, for the T5, you can estimate the achievable top speed in km/h as follows:
Take the cube root of the horsepower, then multiply the result by 33.
Example: 174 horsepower, the cube root of that is 5.583. Multiplying that by 33 gives 184.24 km/h.
VW states the power output as 174 hp and the top speed as 184 km/h.
Best regards.
Christian.
Translated on 15-10-2026, 18:41.
vagtuning
Post16-07-2012, 18:59    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
It would be interesting to know which versions of TN and SW are being used.
The person in question is currently dealing with that.
Translated on 15-10-2026, 18:42.
Mc_Givertechnik
2010 Volkswagen T5
Post08-08-2012, 20:32    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
I found something.
12/23/2010
Address 01: Engine (J623-CAAC) Label file: None.
Part number SW: 03L 906 022 CH, Part number HW: 03L 907 309 K.
Component: R4 2.0L EDC H37 7538.
Revision: 26H37 --- Serial number: 00000000000000
Encoding: 0119401A232400080000
Operating number: WSC 02756 790 50316.
ASAM Dataset: EV_ECM20TDI01103L906022CH 002008
ROD: EV_ECM20TDI01103L906022CH.rod
VCID: 6DD45A870D17
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
Readiness: 0 0 0 0 0
20.11.2011
Component: R4 2.0L EDC H37 8739.
Operating number: WSC 00465 219 91668
ASAM Dataset: EV_ECM20TDI01103L906022CH 002011
VCID: 6DD45A870D01
No errors found.
It would be great to have the old dataset with the AGR control deactivated.
Greetings,
Peter.
Translated on 15-10-2026, 18:45.
vagtuning
Post08-08-2012, 22:08    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
Maybe they should try using the 9126 and see if it's better.
Translated on 15-10-2026, 18:49.
Mc_Givertechnik
2010 Volkswagen T5
Post09-08-2012, 4:51    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
Hello!
Danke für die Info, aber ist die Version 9126 die aktuelle Version? Bei welchen Fahrzeugen wird diese Version eingesetzt? Also, let's see about the T5 as well?
Now it's dawning on me that a change might have occurred even after the update on November 20, 2011. I hope I'll have time to check it out today.
Peter.
Mc_Givertechnik
2010 Volkswagen T5
Post10-08-2012, 20:48    Subject: 23H8 STG Update VW T5 GP, Mehrverbrauch, Leistungseinbußen Quote
Hi everyone!
Here's a scan from today:
Address 01: Engine (J623-CAAC) Label file: RKS\03L-906-022-CAA.clb
Part number SW: 03L 906 022 CH, HW: 03L 907 309 K.
Component: R4 2.0L EDC H37 9126
Revision: 26H37--- Serial number: 00000000000000
Encoding: 0119401A233400080000
ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
VCID: 6DD45A87BC8ADF1
No error codes found.
Readiness: 0 0 0 0 1
So, the current version in this case is 9126, and that specific version is the cause of the problem.
Peter.
Translated on 15-10-2026, 18:51.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VAG-COM Log: VW T4 High Fuel Consumption Issues Upload
No new posts Biodiesel Consumption: ESP/ESD Leakage Issues Diesel Engine Technology
No new posts ASZ Logs: Vibration & Excessive Consumption Upload
No new posts Passat 3B: V6 TDI AFB - Power Loss & Fuel Consumption Diesel Engine Technology
