Button for interior locking - implausible signal?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
psand
Post22-08-2012, 17:04    Subject: Button for interior locking - implausible signal? Quote
Hello, I found the following error code today while performing a diagnostic scan with VCDS:
Wednesday, August 22, 2012, 1:48:27 PM.
VCDS version: RKS 11.11.3
Data as of: 20120406.
Address 62: Door electrics, left and right. Label file: RKS\1K0-959-703-GEN3.lbl.
Control unit part number: 1K0 959 703 K, Hardware version: 1K0 959 703 K.
Component and/or version: Door - SG 006 1206.
Encoding: 0000144
Company number: WSC 69205 141 1012569
VCID: 385079D34B48AA9
"One error found:"
00102 - Button for interior locking; rear left (E310).
008 - implausible signal.
Does anyone have any idea what's wrong with that?
The error reappears immediately after being cleared, and there are no malfunctions or limitations whatsoever with the rear left door...
Thank you for your help, Peter.
Translated on 10-07-2026, 4:51.
Post22-08-2012, 17:10    Subject: Button for interior locking - implausible signal? Quote
Hmm, there shouldn't be a button for the interior locking mechanism in that location. I suspect it's a software glitch.
Relatively speaking, there are software updates for your vehicle for this reason -> Starting from icon_smile.gif.
Translated on 10-07-2026, 4:54.
Post22-08-2012, 19:06    Subject: Button for interior locking - implausible signal? Quote
Do the windows also suddenly move in the opposite direction of the switch's command?
Should I disconnect the battery to do this?
There were some Golf5 door control modules that failed in exactly the same way – the only solution is to replace them.
But icon_smile.gif will be able to clarify that.
Translated on 10-07-2026, 4:55.
psand
Post23-08-2012, 11:59    Subject: Button for interior locking - implausible signal? Quote
First of all, thank you very much for your answers/help!
But does the control unit necessarily have to be broken, considering there are no restrictions or problems with the rear left door?
Best regards, Peter.
Post23-08-2012, 12:08    Subject: Button for interior locking - implausible signal? Quote
Well...
what does "kaputt" mean?
Reichen Dir die Dir bekannten Funktionen? Then it's all done.
Does it make you uncomfortable when a system throws errors related to parts that don't actually exist?
And is that then also distributed via the CAN bus?
Do you know how other ECUs react to that?
... Then I would run it under "Action Required" (colloquially, "broken") icon_smile.gif.
Translated on 10-07-2026, 4:57.
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake manifold flap position: implausible signal Diesel Engine Technology
No new posts Outdoor temperature signal, implausible reading Diesel Engine Technology
No new posts P0471 Error: Unlikely Signal - BLS Troubleshooting Diesel Engine Technology
No new posts Touran Crankshaft Position Sensor - Faulty Signal Diesel Engine Technology
