olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
26-08-2012, 17:52 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Hi there,
Does anyone happen to know where this fuse is located?
"Nothing seems to be working with the candles anymore, and I wanted to fix that before winter."
Best regards from Berlin.
olli A6 CANA/JME /
Ex-A6 AEL
Translated on 21-08-2026, 18:01.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
26-08-2012, 18:40 Subject: Glow Plug Replacement Audi A6 C4 AEL |
As far as I know, it's located on the passenger side, in the footwell or near the A-pillar. LG, Onkel BM
Translated on 21-08-2026, 18:02.
26-08-2012, 18:45 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Hmm.
There are 3 relays for the engine heating system and for the EDC (Electronic Damping Control).
That's all, but thanks for the tip anyway.
olli A6 CANA/JME /
Ex-A6 AEL
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
26-08-2012, 20:11 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Hello.
The fuse box is located on the passenger side, under the carpet, underneath the glove compartment.
To access that area, you need to pull the carpet to the left, towards the wheel arch and in the direction of the gear lever.
Then you can fold back the carpet, remove the A-pillar trim and the door sill cover on the passenger side to gain a little more space.
You can hardly tell if you don't know what to look for!
There are still two black plastic covers that need to be removed.
Now you can see the silver engine control unit, and to its right , there is a small black plastic housing containing a metal strip fuse for the glow plugs / 80A.
Do not confuse this with the metal strip fuse for the electric heater in the heat exchanger, which is protected by a 50A fuse.
Mpire. fehlen Dir die Worte, entscheiden die Taten!
Translated on 21-08-2026, 18:04.
Profile PM Garage |
26-08-2012, 20:20 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Hi there,
So, is the EDC really located under the passenger's feet? I saw a black plastic cover underneath the carpet, but I didn't want to remove the entire carpet.
Okay, I'll take a look tomorrow then...
Thank you.
olli A6 CANA/JME /
Ex-A6 AEL
Translated on 21-08-2026, 18:06.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
26-08-2012, 21:05 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Yes, with a carpet knife and a small cut, you can remove that part in 5 minutes, and everything will be fine afterward.
Translated on 21-08-2026, 18:07.
Profile PM WWW Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
26-08-2012, 21:48 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Be careful, because the carpet can tear very easily and then looks very unsightly.
Be mindful of moisture, as the water reservoir in the C4 can quickly become full, and the MSTG (presumably a sensor or component) is located in a rather inconvenient place in the footwell. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
wolle Blaumann
29-08-2012, 8:46 Subject: Glow Plug Replacement Audi A6 C4 AEL |
Hi everyone,
@Olli
The carpet is also pre-marked, making it easy to see where you should position the carpet knife. It's also helpful to remove the cover panel in the passenger footwell, which you already had in your hand. This allows you to fold the carpet back far enough.
Wool. 2018er A6 Avant Allroad, 3.0 Bi-TDI mit prima Ausstattung
Translated on 21-08-2026, 18:08.
