28-07-2012, 9:49 Subject: Differential Pressure Sensor: How Many Ports? |
HI.
Does the differential pressure sensor have an ATM connection, meaning an open end, or is it defective?
| Description: |
| Anschluß Differenzdruck Sensor im 7M |
| File size: |
92.33 KB |
| Viewed: |
20850 times |
Translated on 26-08-2026, 20:34.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
28-07-2012, 10:51 Subject: Differential Pressure Sensor: How Many Ports? |
Hmm, what kind of engine is installed in there? *thinking*
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
28-07-2012, 12:31 Subject: Differential Pressure Sensor: How Many Ports? |
Hello Martin,
Check this out:
/viewtopic.php?t=25781
Best regards.
Dirk.
Translated on 26-08-2026, 20:35.
28-07-2012, 12:59 Subject: Differential Pressure Sensor: How Many Ports? |
Great, thanks.
It's a CFFB in a VW Sharan (MJ11).
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
28-07-2012, 14:01 Subject: Differential Pressure Sensor: How Many Ports? |
Correct, it is normal depending on the model.
Just to be on the safe side, I should mention that such a "connection" is not possible or useful if the DPF uses a second connection for the differential pressure sensor.
Therefore, you cannot simply choose freely between the two possible connection types; instead, when performing repairs or modifications, you must use the same variant as before, because the software in the engine control unit expects it.
Translated on 26-08-2026, 20:36.
Profile PM WWW Garage |
Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
29-07-2012, 15:12 Subject: Differential Pressure Sensor: How Many Ports? |
Hi Martin,
With the differential pressure sensor shown here, which has an ATM connection, you can directly measure the back pressure after the turbocharger and before the DPF, and not just the pressure drop across the DPF.
I'm interested in knowing what the back pressure is. Do you have any measurement data from full-throttle runs?
Best regards, Georg.
Translated on 26-08-2026, 20:38.
Profile PM Garage |
30-07-2012, 11:14 Subject: Differential Pressure Sensor: How Many Ports? |
I don't have any data.
I had the car for the entire weekend, but it was more of a "static display."
All the related and friendly families were there, and generally, everyone wants a car like that, but each person still needs to figure out the price.
We were more concerned with getting in and out, securing child seats, etc.
I don't want the CFFB; it's clunky and too weak.
Again, a CR  that vibrates more than my PPD - just like all five of the 140 HP CR models I've driven so far.
Translated on 26-08-2026, 20:39.
Profile PM Garage |
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
31-08-2012, 21:39 Subject: Differential Pressure Sensor: How Many Ports? |
"Could they be doing this to directly measure the pressure for the lambda sensor's pressure compensation, instead of relying on a model?"
They probably already have a complex model for soot loading. Whether they use differential pressure or back pressure depends on whether they model the DPF as a simple container or as a "container with a pipe attached to the back."
However, pressure compensation for the lambda sensor is simplified and improved because it provides a direct measurement, rather than relying on a pressure model at this point, which may be affected by the variable loading of the DPF or be difficult to implement.
Translated on 26-08-2026, 20:40.
