Bolzer Blaumann
01-09-2012, 21:21 Subject: Adjustable Injection Start: Not Configurable |
Hi.
We have a problem with our Audi A4 B5 AFN (year of manufacture 1996) where the dynamic injection timing cannot be adjusted.
The following actions were taken.
The ABS unit was leaking. I removed it and took it to a Bosch service center in Estenfeld to have it repaired, sealed, and inspected. I thought that after 270,000 kilometers, the old girl deserved it.
"I got the pump back yesterday. 'Everything is fine. The pump has been sealed and adjusted.'"
Today we installed the pump. The timing is perfect. The alignment and fitting of the pump were excellent.
Key turned, engine started immediately.
In idle state, the value in field 2 of module MWB 000 is approximately 53.
In the default setting, I can almost fully adjust the range, but I don't get any values above 000. It always displays that the injection timing is too early to show a value.
The engine runs smoothly when the injection timing is set to "normal."
What I've noticed.
The fuel injection start timing (MWB 004) is within the expected range and functioning correctly.
But:
The start of injection, even at idle, is between 1.3 and 1.8 degrees before top dead center (BTDC).
If I increase the speed until it reaches 2100 RPM, the value goes to -2.6° relative to top dead center (TDC).
Above 2100 RPM, the injection timing shifts back towards before top dead center (BTDC).
Bei 4000U/min bin ich schon wieder bei 10°v. Off-topic.
Could it be possible that the pump is not working properly?
Or maybe I made a mistake.
The valve timing is definitely correct.
Do you have any other suggestions?
There are many threads on this topic, but I haven't been able to find a solution using them.
I also have a log file from MWB 000,001,004, starting from idle and going up to approximately 4300 RPM.
Bolzer.
| Description: |
 Download |
| File name: |
LOG-01-000-001-004_02.CSV |
| File size: |
2.68 KB |
| Downloaded: |
590 times |
Translated on 13-08-2026, 4:45.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
01-09-2012, 22:05 Subject: Adjustable Injection Start: Not Configurable |
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 13-08-2026, 4:49.
Profile PM WWW Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
01-09-2012, 22:47 Subject: Adjustable Injection Start: Not Configurable |
Are you sure that you have also set the "TimingChecker" to AFN mode?
Profile PM Garage |
Herbert Profi-Schrauber
01-09-2012, 23:14 Subject: Adjustable Injection Start: Not Configurable |
Hi there,
The measured values are independent of the model, but the tolerance range depends on the engine.
It appears that the ESP is significantly out of phase, which explains the "000" reading in MWB2. This also aligns with the fact that I'm seeing a duty cycle of 78% in the LL (Low Level) signal, whereas I only see 3%.
The EDC system manages the situation reasonably well under the shown conditions; therefore, outside of the basic settings, the "normal" values are displayed, and the adjustment is made early on based on engine speed.
Translated on 13-08-2026, 4:50.
Bolzer Blaumann
02-09-2012, 0:25 Subject: Adjustable Injection Start: Not Configurable |
Hi.
The timing checker was set to the AFN mode.
OK. Du meinst dass der Spritzbeginn deutlich zu spät ist. Ich werde am Montag nochmal eine Grundeinstellung vom Spritzbeginn machen. Let's see.
Bolzer.
Translated on 13-08-2026, 4:52.
02-09-2012, 7:51 Subject: Adjustable Injection Start: Not Configurable |
Hi there.
What static value did you set when installing the pump?
Uli S. Schrauber
Joined: 07/02/2003 Posts: 338 Karma: +7 / -0 Location: Äußerster Südwesten
02-09-2012, 13:38 Subject: Adjustable Injection Start: Not Configurable |
Herbert wrote: | It seems that the ESP is significantly out of phase, which explains the 000 value in MWB2. This also aligns with the fact that I'm seeing a duty cycle of 78% in the LL, whereas I only see 3%.
Conversely: The higher the water level (TV), the lower the internal pressure of the pump, which leads to a later start of the system (SB).
To me, it looks more like the pump is slightly advanced in its timing. In low load conditions, it's not able to adjust the target value sufficiently towards a later point, even though the duty cycle is already at its maximum (94%).
(SHOULD) (IS) TV
∞v.OT ∞v.OT %
1. 3 1.8 78.5
1. 3 1. 8 94
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 13-08-2026, 4:54.
02-09-2012, 16:34 Subject: Adjustable Injection Start: Not Configurable |
Negative values for the "low" duty cycle percentage mean a high valve activation level. In the initial setting mode, 0% corresponds to full activation.
Try it out, for example, by starting the actuator diagnosis - proceed to test the injection start valve, then exit the diagnosis and view parameter group 4 (PG4). Afterwards, you will of course need to complete the actuator diagnosis.
Or search the forum. There was an article there about how to adjust the ESP for optimal control values. At high power output and thus earlier injection timing, it's best not to exceed 95% so that there is still some reserve.
Translated on 13-08-2026, 4:56.
Bolzer Blaumann
02-09-2012, 22:17 Subject: Adjustable Injection Start: Not Configurable |
Hi.
I'm sorry I didn't reply today.
Family outing. It's nice to not have to think about cars for once.
Ich hatte den Förderbeginn mit der Messuhr eingestellt. Value approximately 0.7.
But I had to return the watch to the service center again. Maybe I'll get it back sometime.
However, what makes me a bit uneasy is the fact that the pump was disassembled and cleaned by a professional company. I'm not sure what they did to the pump during that process.
Could the problem possibly be related to the pump? I wouldn't want to spend a week troubleshooting something that might not even exist.
But please don't misunderstand me. I'm not trying to imply that the workshop made a mistake, but rather to rule it out as a possibility.
Bolzer.
Translated on 13-08-2026, 4:59.
03-09-2012, 3:52 Subject: Adjustable Injection Start: Not Configurable |
Hi there,
The 0.7 mm movement at TDC seems correct, provided no errors were made during the measurement (timing chain tension, clock preload, zero setting, finding TDC by rotating the crankshaft in the direction of rotation, reading the TDC mark). Otherwise, I would have suspected that the timing wheel for the ESP was off by one tooth when installing the timing chain.
Please check the adjustment range of the injection timing control using the actuator diagnosis; that is, exit the "Injection Timing Valve" test step and observe parameter group 4 (PG4). The valve will be controlled between its minimum and maximum positions for approximately 30 seconds. What values do you see for the target value, actual value, and duty cycle?
Otherwise, check the injection timing under varying load conditions using VCDS (data logging) and voltage measurement ( https://community.dieselschrauber.org/en/viewtopic.php?t=3195 ).
Translated on 13-08-2026, 5:01.
Uli S. Schrauber
03-09-2012, 9:22 Subject: Adjustable Injection Start: Not Configurable |
Herbert wrote: | Negative - a "low" duty cycle in % means high valve actuation. In the basic setting mode, you have 0% = full actuation.
Oh wow, I totally messed that up  ... Sorry, you're absolutely right. High TV adjusts after early, not after late.
Best regards, Uli.
Bus T3 JX
2x Golf2 GTD/SB
96er Passat 35i AFN
Translated on 13-08-2026, 5:03.
Bolzer Blaumann
04-09-2012, 22:16 Subject: Adjustable Injection Start: Not Configurable |
Hi.
He is running.
Ich hab den Adapter für die Messuhr leider diesmal nicht bekommen. But it doesn't matter.
I first marked the entire adjustment range of the pump and then turned the pump to the first third of its range.
Surprisingly, the values matched quite well.
And most importantly, the default setting also had a value of 012.
Slightly better adjusted, let the engine warm up, and then set the timing precisely using the TDI timer.
Now the values are correct.
I don't know what I did wrong the first time, and I can't figure it out anymore. But definitely, the injection start was set too late.
I know what my second mistake was. I wrote that I had tested the entire adjustment range. Unfortunately, I only used the adjustment range allowed by the fuel injection lines. I have to admit that I didn't loosen the lines, which meant the adjustment range was too small, and therefore I didn't reach far enough into the early injection phase.
A small, stupid beginner's mistake. I am also ashamed of it.
It's very frustrating because I'm already replacing the timing belt for the third time on this engine, and I've also replaced several of these pumps before.
Here are the logs for the current configuration.
One is set to the default setting, and the other goes from idle up to 4000 RPM.
The duty cycle is still around 55% in the LL (likely referring to a specific component or system).
Thank you very much for your help.
Bolzer.
| Description: |
 Download |
| File name: |
LOG-01-000-xxx-xxx-Grundeinstellung.CSV |
| File size: |
2.26 KB |
| Downloaded: |
473 times |
| Description: |
 Download |
| File name: |
LOG-01-000-004-xxx.CSV |
| File size: |
5.57 KB |
| Downloaded: |
458 times |
Translated on 13-08-2026, 5:05.
05-09-2012, 9:01 Subject: Adjustable Injection Start: Not Configurable |
Hi there,
What surprises me:
- Under normal operating conditions, the injection timing at idle is controlled to be significantly earlier than in the basic setting mode, approximately 1° before top dead center (TDC). With a warm engine, it should be later.
- With a slightly elevated lambda value, the injection start timing suddenly shifts to before top dead center (BTDC).
At first, I thought it might be related to the pressure ratio in the LL (low-level), possibly due to something with the pump's internal pressure, but the actual values are following the setpoint values.
Translated on 13-08-2026, 5:09.
