Brake Wobble & Steering Issues
Post02-11-2012, 11:00    Subject: Brake Wobble & Steering Issues Quote
Here are two observations I've made about our golf course:
(1)
- The brakes were making a rubbing noise, so I replaced the front brake pads and rotors with new VW parts.
- Now (I'll provide the age and mileage of the brakes later), the rattling sound is back.
(2)
My wife always brakes too much when she's maneuvering.
That's causing the front brakes to squeal.
Now, the question is:
Can (2) somehow wear down the glass in certain areas to the point where (1) is created?
The TÜV inspector today confirmed that the wheel bearings are functioning correctly, even after being specifically asked about them in relation to the brake noise.
I don't want to have to pay for another set of brake pads again.
Translated on 23-09-2026, 0:17.
Karma: +1100 / -0   Thank you, like it!
Post02-11-2012, 11:06    Subject: Brake Wobble & Steering Issues Quote
Do you see anything in the diagram of the discs?
Translated on 23-09-2026, 0:18.
Post02-11-2012, 11:15    Subject: Brake Wobble & Steering Issues Quote
No, not really.
I couldn't "see" anything unusual on the old windshields either, even the ones that had been replaced due to scratches.
I haven't yet dared to put your idea of hot-air braking into practice.
Translated on 23-09-2026, 0:19.
Post02-11-2012, 15:48    Subject: Brake Vibration & Steering Issues Quote
The brakes only show noticeable wear when they need to convert a significant amount of energy (i.e., a good amount of wheel speed plus braking pressure). This is unlikely to happen when the vehicle is almost stationary.
However, I would try to discourage her from that behavior, primarily to protect the steering components icon_biggrin.gif.
Translated on 23-09-2026, 0:20.
Post02-11-2012, 22:25    Subject: Brake Wobble & Steering Issues Quote
Even after coming to a stop, the brake pads can still "hold" onto the hot brake discs, which can cause uneven cooling and warping of the material.
No new posts Audi 80 B4: Steering and Handling Transmission, Chassis, Body & Interior
