VAG Radio Antenna Amplifier: Power Supply
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Octavia_4x4
Post14-11-2012, 13:10    Subject: VAG Radio Antenna Amplifier: Power Supply Quote
I have a rather specific problem. I need to install a windshield antenna on a vehicle that belongs to a friend.
The factory radio, the VW MCD, is known to have a 12V supply for the antenna amplifier on its cable.
"If I now install a windshield antenna adapter, will it be able to handle that? It itself is powered by the ignition positive terminal, but what damage could it cause if the connected antenna cable receives 12V?"
Greetings.
Translated on 16-07-2026, 1:37.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post14-11-2012, 14:00    Subject: VAG Radio Antenna Amplifier: Power Supply Quote
It is powered directly by the ignition plus line.
Then it's the wrong amplifier adapter!
reflexsilber met.
Translated on 16-07-2026, 1:38.
Octavia_4x4
Post14-11-2012, 14:07    Subject: VAG Radio Antenna Amplifier: Power Supply Quote
"What exactly is happening? He couldn't find any windshield antennas that were powered by voltage through the antenna cable..."
Translated on 16-07-2026, 1:39.
RedR32
Avatar-RedR32
Post14-11-2012, 14:23    Subject: VAG Radio Antenna Amplifier: Power Supply Quote
windschutzscheibenantennen mit Spannung über Antennenleitung hatte er keine gefunden...
Der Verstärker sitzt auch nicht an der Windschutzscheibe! At OEM.
Should you already know whether the windshield antenna requires an amplifier?
When using phantom power and a simple antenna, nothing will happen; it shouldn't have any ground connection.
reflexsilber met.
Octavia_4x4
Post14-11-2012, 15:38    Subject: VAG Radio Antenna Amplifier: Power Supply Quote
I think I didn't express myself clearly. It's a car radio. It has a 12V voltage on the antenna lead from the factory.
The existing roof antenna needs to be removed. It will be replaced with a universal windshield antenna, which has an integrated amplifier with positive and negative terminals.
My fear is that either the antenna amplifier or the radio will stop working.
Translated on 16-07-2026, 1:40.
No new posts Power supply for the EDC Diesel Engine Technology
No new posts Is the power supply sufficient? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Octavia 5E voltage supply fault, control unit 69 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Error 00532 - Power supply / Short circuit after positive... Diesel Engine Technology
