grundlegender Wechsel der CR-Injektoren (Piezo -> Magnet) | Posts 16+
Go to page: Previous  1, 2
chris11
Karma: +3 / -1   Thank you, like it!
Post31-08-2012, 21:17    Subject: Quote
http://www.spiegel.de/auto/aktuell/mercedes-autos-hatten-motor-mit-defekten-injektoren-a-853276.html
Best regards.
Christian.
Translated on 03-09-2026, 0:50.
Post03-09-2012, 11:28    Subject: Quote
Do the MJ12 Audis still have CR (Common Rail) engines?
possibly only version 3.0, but not version 2.0 anymore?
At least, that's what it says in the current A6 brochure.
Translated on 03-09-2026, 0:51.
Blackfrosch
Post04-09-2012, 11:10    Subject: Quote
Skoda Service Training 80 - TDI CR 2nd Generation
Piezo injectors, maximum 6 injections per cycle.
Magnet injectors, maximum 7 injections per cycle
I cannot say whether the engines are now being used in a different way, and whether the total injection time has increased by more than 1/6.
Maybe training materials aren't meant to tell employees, "Hey, we've made something cheaper again, and worse – great, right?"
We will never know for sure. Anyone interested in the documents can feel free to contact me via private message. I'm just sharing what I've read.
Hi Blackfrosch,
Translated on 03-09-2026, 0:52.
Malte1408
Post04-09-2012, 22:11    Subject: Quote
Well, is the solenoid valve now worse?
There used to be ceramic glow plugs, but they've disappeared from the market again...
Regarding the 2.0L CR-TDI engines of the "second generation," it's also important to note that they no longer have a variable intake manifold.
The AGR cooler module is the same as the one used in the 1.6-liter engine with the N18, located at the rear and routed through the cylinder head.
And the oil pump, which is driven by a timing belt.
Translated on 03-09-2026, 0:53.
Post05-09-2012, 22:23    Subject: Quote
I did some research:
The CFFB (a 140 hp mass-produced engine in VW vehicles) and the CGLC/D (a 177 hp engine in the A6) have the same injectors... so they are all solenoid-type injectors.
Translated on 03-09-2026, 0:54.
Peter vdl
Post14-11-2012, 20:47    Subject: Quote
Hi everyone,
It all depends on the technology within the injector. The older, indirectly controlled solenoid injectors can perform up to two pre-injections and one post-injection. Piezo injectors, at least those from Bosch, also indirectly controlled, can perform up to five pre-injections and two post-injections. Modern solenoid injectors work directly on the nozzle needle and are therefore just as fast as piezo injectors, but unlike piezo injectors, they have a defined zero position and are cheaper to manufacture. They are also more robust and, as far as I know, do not require the same complex hydraulic systems as piezo injectors.
Smoky greetings.
Peter.
Translated on 03-09-2026, 0:55.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Piezo Injectors: 3.0 TDI - Installation & Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. Enter Piezo Injector :Pparameters using VCDS (3.0 TDI/BMK) Diesel Engine Technology
No new posts Piezo PD System: New Information and Details Diesel Engine Technology
No new posts Wie Piezo-Injektor in ausgeb. Zustand prüfen? (Audi A6 4F) Diesel Engine Technology
