VCDS-RKS Compatibility with Windows 8
Post05-11-2012, 19:52    Subject: VCDS-RKS Compatibility with Windows 8 Quote
VCDS-RKS can be installed on Windows 8 and functions as expected.
To do this, download the setup file (save it on your computer). In the file manager, right-click on the file and select "Handle compatibility issues".
It is recommended to use "Windows 7" as the installation environment. Then, go to "Troubleshooting Program Problems" and select "This program was working in previous versions of Windows..." and choose "Windows 7". TEST it and pay attention to the administrator symbol in the taskbar (Run Setup).
Okay.
 VCDS-RKS, KPower, KDataScope und Windows 8
 File size:  74.15 KB
 Viewed:  2358 times
Translated on 27-09-2026, 22:40.
Post10-11-2012, 15:36    Subject: VCDS-RKS Compatibility with Windows 8 Quote
Tip for easier use of Windows 8:
http://classicshell.sourceforge.net/
The free tool, which is licensed under the GPL, adds a Start menu and a toolbar for Internet Explorer in Windows 8.
Translated on 27-09-2026, 22:41.
Post11-01-2013, 19:44    Subject: VCDS-RKS Compatibility with Windows 8 Quote
Win 8 support and KDataScope 1.20, along with data updates (labels, etc.), are now available in VCDS-RKS version 11.11.5.
Changes in version 11.11.5:
- Firmware update for HEX-USB/HEX-USB+CAN.
- New version of LCode (a tool for long-form coding assistance).
- Improved MicroCAN compatibility for the New Beetle 5C.
- Update engine control unit documentation/labels.
Translated on 27-09-2026, 22:42.
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS and Windows 10: Compatibility & Setup On-Board Diagnostics (OBD)
No new posts VCDS: Not Compatible with Windows NT 6.1 On-Board Diagnostics (OBD)
No new posts HEX-USB+CAN, KEY-USB, HEX-USB, new Windows and drivers On-Board Diagnostics (OBD)
No new posts HEX-USB+CAN for Windows 11, starting April 2026, drivers On-Board Diagnostics (OBD)
