Volvo S60 Kühlmittelstand | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Post06-12-2012, 1:36    Subject: Quote
Maybe the pressure relief valve in the coolant cap is broken?
Put a new lid on it,
That would mean that the pressure relief valve is not opening, or is opening too late.
If a closed system with an expansion tank has a properly functioning valve that opens, you will inevitably have a problem with the coolant pressure.
Translated on 03-10-2026, 13:51.
Karma: +590 / -0   Thank you, like it!
Post06-12-2012, 22:54    Subject: Quote
Hi!
Let me think.
The lid (at least in some models) has two valves in it.
I haven't really explored the functionality yet.
There's a valve that allows air to enter when a certain vacuum pressure is reached, as the engine cools down.
Then there's another valve that releases the air that has been drawn in, at a predetermined overpressure, when the engine gets warm.
If the exhaust valve is not working, but the intake valve is functioning.
The effect described here could potentially occur.
I think so, at least.
Otherwise, when there are problems with the cylinder head gasket, it's usually described as if it's erupting like a geyser or spurting out from the water reservoir when the engine is hot.
when the CO₂ dissolved in the coolant reverts to gas bubbles due to the pressure loss. This only happens as long as the coolant is below 100°C.
I feel like that's missing from the description.
Translated on 03-10-2026, 13:53.
chriskross
Post07-12-2012, 12:30    Subject: Quote
What I also noticed is that the radiator hose that runs from the thermostat to the upper radiator connection is completely cold.
A6 AFB
A6 BRE DPF
Translated on 03-10-2026, 13:54.
Post07-12-2012, 22:30    Subject: Quote
chriskross wrote:
What I also noticed is that the coolant hose, which runs from the thermostat to the upper radiator connection, is completely cold.
Hi!
Well, there it is.
Either the thermostat isn't opening properly, or it hasn't been bled correctly. As I suspected.
Check if there's a bleeder valve at the top of the radiator, or if necessary, disconnect the upper radiator hose.
Then, fill it with coolant until it's full.
You can easily detach the hose so that only a small opening remains at the top, and then fill it with a small container of coolant.
Translated on 03-10-2026, 13:55.
chriskross
Post21-01-2013, 23:15    Subject: Quote
Good news: since the thermostat was replaced, everything is working properly again.
A6 AFB
A6 BRE DPF
Translated on 03-10-2026, 13:56.
Post21-01-2013, 23:49    Subject: Quote
That sounds good, and thank you for the feedback icon_wink.gif.
Translated on 03-10-2026, 13:57.
No new posts Fluctuating coolant level in new 2.0L TSI engine Gasoline Engine Technology
No new posts Kühlmittelstand Polo 9N 1,4TDI Hilfe!!! Diesel Engine Technology
No new posts Volvo TDI = VAG TDI? Diesel Engine Technology
No new posts Volvo V70 A6 AGR Seat - For Sale Diesel Engine Technology
