Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure (Solution)
Post26-01-2013, 14:13    Subject: Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Quote
On the example vehicle, a 2.0 TFSI engine is installed. The procedure for retrofitting GRA is generally very similar for vehicles from around 2006.
{TEXT}
- Cruise control lever
- Steering column control unit, which supports cruise control.
Procedure:
- Perform a vehicle scan and save it, which includes, among other things, all the coding settings of the installed control units.
- Install new steering column control unit and cruise control lever.
- Recode the engine control unit and steering column control unit. The value from the old control unit will be used as the basis for coding the new steering column control unit. Using the coding assistant in VCDS, configure the GRA in both ECUs.
Ratings - Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V 1.4 Gasoline GRA retrofit failed Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf IV ARL does not start after GRA modification. Diesel Engine Technology
No new posts Cruise control in A3 8P using a Golf 5 lever Diesel Engine Technology
No new posts Cruise control module for Caddy (Golf), part number 1k095... On-Board Diagnostics (OBD)
