A4 Engine Docs: AVF, Declining Shift Quality (Solution)
Michael II
Post28-08-2003, 21:45    Subject: A4 Engine Docs: AVF, Declining Shift Quality Quote
MKB: AVF, GKB: FPN
Problem description.
The shifting quality of the first and second gears has deteriorated with mileage. This degradation in shifting quality is noticeable across all operating temperature ranges.
Cause.
Damaged synchronizer ring coatings on the first and second gears, resulting in wear to the clutch teeth on the synchronizer rings, the sliding sleeve, and the shift gears.
Solution:
Carbon-coated synchronizer rings. The synchronizer rings should always be replaced together with the sliding sleeve. Depending on the wear pattern, the gears may also need to be renewed. In this case, the gearbox does not need to be replaced.
Repair kit: 01E 398 270
"Note:"
They are attempting to charge customers for this action. The VAG's stated reasoning is:
"The synchronizer rings were damaged due to gear changes performed with the clutch pedal not fully depressed. Therefore, no goodwill warranty will be applied."
Tschüss
Michael II
Translated on 20-08-2026, 2:31.
Ratings - A4 Engine Docs: AVF, Declining Shift Quality
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
