AVF Engine Noises: Troubleshooting Guide (Solution)
Michael II
Post28-08-2003, 22:09    Subject: AVF Engine Noises: Troubleshooting Guide Quote
Knocking sounds at idle, injector pump, part number: AVF.
Cause.
The knocking sounds are caused by pulsations in the vacuum line between the solenoid valve and the exhaust gas recirculation (EGR) valve. The diaphragm of the EGR valve vibrates in the same rhythm as the vacuum pulsations.
Solution:
Replace the three-part vacuum line between the solenoid valve and the exhaust gas recirculation valve (consisting of a fabric hose, a pipe, and an elbow) with a single fabric hose of the same diameter, part number N 020 282.1.
Tschüss
Michael II
Translated on 09-10-2026, 14:36.
Ratings - AVF Engine Noises: Troubleshooting Guide
No new posts Document: Quacking sounds from AGR, AJM, and ATJ engines. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Onboard Network Management: Documentation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation (EGR) gurgling noises / TDI 130hp Diesel Engine Technology
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
