ducmen9 Guest
27-08-2003, 21:09 Subject: Manual climate control > Map-based cooling? |
Hallo, ich baue gerade in einen 100Ps TDI (AXR) eine manuelle Klima ein. Jetzt habe ich einen Kabelbaum (von einem Unfallwagen) ausgebeint und habe dabei festgestellt, das dieser eine manuelle Klima mit Kennfeldkühlung hat. Beim Temperaturschalter (Drehregler) geht ein Kabel ab. Bei dem Modell ohne Kennfeldkühlung ist der Stecker nicht vorhanden. Aus dem Schaltplan meines Motors geht auch nichts hervor. Kann ich diese Kabel einfach unberücksichtigt lassen? UnWhat exactly is map-based cooling?
Best regards and thank you, Thomas.
Translated on 16-07-2026, 16:15.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
28-08-2003, 6:38 Subject: Manual climate control > Map-based cooling? |
What kind of vehicles are we talking about? Tschüss
Michael II
Translated on 16-07-2026, 16:16.
ducmen9 Guest
28-08-2003, 11:03 Subject: Manual climate control > Map-based cooling? |
It's a Golf4 Estate (2002) with a 100hp common rail diesel engine (AXR). I got the air conditioning unit from a car dismantler who no longer remembers which vehicle it came from. However, in the wiring diagrams for a 1.6 Motronic (BAD) engine from 2001 onwards, I found the control signal for the heater switch. But I'm not sure if I can simply omit that control signal...
Best regards, Tom.
29-08-2003, 6:34 Subject: Manual climate control > Map-based cooling? |
"In this context, the term 'map cooling' refers to engine cooling."
If your wiring harness is otherwise correctly wired, you can connect the additional connector without connecting it to anything. Tschüss
Michael II
Translated on 16-07-2026, 16:17.
ducmen9 Guest
29-08-2003, 6:41 Subject: Manual climate control > Map-based cooling? |
'Thank you, I was almost driven crazy... So, installing an air conditioner is really not a piece of cake, but now I have the cables, the compressor, and the pipes inside. I spent two whole days working on the wiring harness + studying the circuit diagrams!!! That's the A and O. If something goes wrong here, it's all for nothing.'
Best regards, Thomas.
Translated on 16-07-2026, 16:18.
