Golf 5 1,9 TDI 5 Gang 6 Gang Getriebe ZMS Kupplung | Posts 16+
Go to page: Previous  1, 2
Post14-02-2013, 1:37    Subject: Quote
derjanzen wrote:
The graph makes me a little suspicious....According to this, the 5th and 6th gear have EXACTLY the same gear ratio?!
NO
the red lines represent the Passat (2-6 gears, I haven't logged the first one properly).
The blue lines of the Gulf.
Additionally, I have plotted the 4000 km/h mark, so that you can easily see the recorded Vmax.
But be careful, these are km/h from VCDS - the speedometers are still a few % higher.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post14-02-2013, 18:12    Subject: Quote
Gear Type 0A4
5th Gear GQQ i=0.7345
" HNV i=0,7 (Passat)
2 Räder, ca. 250€, ohne Getriebe-Umbau, austauschbar
reflexsilber met.
Post15-02-2013, 9:25    Subject: Quote
Okay,
I could give our next one a longer 6.
On T4 AAB, it really worked, managing to get 0.68 (or so) in.
Sieders
Post15-02-2013, 13:21    Subject: Quote
Can the 6th gear be extended in these 5 icon_smile_thumb_up.gif transmissions? I also have a JYJ in my Golf.
Greetings
Post15-02-2013, 15:02    Subject: Quote
Among the closest relatives, JYJ has been the longest 6th.
I still don't know what else fits.
Post15-02-2013, 15:28    Subject: Quote
The AD/AE combination is exactly that of GQQ.
Here is some information about it.
http://www.t4-wiki.de/wiki/Getriebe_%28Langer_5._Gang%29
Blackfrosch
Post10-03-2013, 2:39    Subject: Quote
Are the gearboxes for the 2.0 TDI engines compatible with the 1.9 TDI engine without any modifications? Does anyone know exactly what needs to be changed? That might also be an option...
Coupling, Starter, Drive shafts, Starter, Torque support, Gearbox bearing/mounting. And then, theoretically, there's also the TÜV (German technical inspection), because the gear ratio relevant to emissions will change by more than 8%.
Greetings
Post10-03-2013, 12:41    Subject: Quote
Basically, it's about the replacement of MQ250 with MQ350.
To add another point, and for this to be possible:
The cables in the gear are different.
mullemaus
Post10-03-2013, 13:47    Subject: Quote
Just finished the conversion from MQ250 to MQ350.
Even with the older Golf 4, the tow cables were identical. The only difference in the gear linkage was partial (ball head to socket version) icon_wink.gif
Post10-03-2013, 20:08    Subject: Quote
Switch from ...AD to ...AC at MQ350
Dito for the shift cable: AT and AR
I can also quickly remove and check my two air filter housings icon_smile.gif
I have an MQ250 and an MQ350 here.
Maybe 2-3 photos would also work.
Because the modification of the gear lever (on the gearbox) proved to be somewhat different.
OK, whether the trains MUST be different, I don't know.
Here's at least something different:
[img]/download.php?id=5338[/img]
mullemaus
Post10-03-2013, 20:13    Subject: Quote
Switch from ...AD to ...AC on MQ350
The gear mechanism/pulley is different. The cables themselves and the curtain fit perfectly. Pull out at the front of the rope, re-tie, done. icon_cool.gif icon_wink.gif
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 5-Gang Getriebe auf 6-Gang Getriebe erweitern beim G3 AHU Diesel Engine Technology
No new posts 6-speed gearbox for Golf 3 TDI (AFN) ? Diesel Engine Technology
No new posts Gibt es ein 5-Gang Getriebe für Golf 2, 1,3l, 40kw NZ-Mo... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
