GarfieldMZ Guest
30-08-2003, 19:42 Subject: Audi A6 (4B) vibrates from 140 km/h |
Hello everyone!
I'm having a small problem. For some time now, my A6 has been vibrating on the highway at speeds of around 140 km/h (approximately 87 mph). The front tires were recently balanced during installation. You don't really feel a strong vibration in the steering wheel, but rather it feels like the entire car is vibrating. The rear tires were balanced last year, and the weights are still all attached, so nothing has fallen off. I'm out of ideas about what else it could be. You don't notice anything at lower speeds.
Does anyone have any ideas about what triggers this effect, or how to get to the bottom of it?
Thank you for your help!!
DENNIS
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
31-08-2003, 0:04 Subject: Audi A6 (4B) vibrates from 140 km/h |
Hi Dennis!
Have you ever checked your tie rod ends for play?
With that kind of mileage, several suspension components are likely worn out!
Alex. AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
GarfieldMZ Guest
31-08-2003, 9:46 Subject: Audi A6 (4B) vibrates from 140 km/h |
Hello Alex!
Yes, I had that done too. Everything should be fine. This week, the TÜV inspection found nothing wrong with the vehicle except for a small oil leak from the valve cover gaskets.
Hi Dennis!
Alex
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
31-08-2003, 10:13 Subject: Audi A6 (4B) vibrates from 140 km/h |
Are all the wheel bearings in good condition? Tschüss
Michael II
GarfieldMZ Guest
31-08-2003, 11:32 Subject: Audi A6 (4B) vibrates from 140 km/h |
Hello Michael!
You don't hear anything from the wheel bearings.
I honestly don't know if they have any games.  I'll test it out, though...
Or do you mean something else?
DENNIS
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
31-08-2003, 22:56 Subject: Audi A6 (4B) vibrates from 140 km/h |
Excessive play in the rear wheel bearings can cause this effect.
Also, these are also tires that show fabric tears on the inside. You might want to have the rear ones checked.
The constant velocity joints of the drive shafts may be worn out due to mileage. When the vehicle is stationary, these joints should not have any radial play. It is usually harmless if you can slightly distort the waves without the wheel moving.
Olli.
