Testing: Other Fields & Data Fields.
michiglaser
2007 Audi A4 Avant
Post04-04-2013, 23:17    Subject: Testing: Other Fields & Data Fields. Quote
Hello!
I've heard something that I actually find hard to believe...
Is it conceivable that a car of the current generation, primarily to reduce fuel consumption, might actually use different engine control parameters when it detects, through various sensors (e.g., ESP), that it is being "driven" on a dynamometer?
Sure, here's the translation:
"Thx."
Michael.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 04-10-2026, 19:44.
mullemaus
Post04-04-2013, 23:46    Subject: Review: Are Other Data Fields Under Scrutiny? Quote
Hello!
I've heard something, and frankly, I find it hard to believe...
Is it conceivable that a car of the current generation, primarily to reduce fuel consumption, might actually use different engine control parameters when it detects, through various sensors (e.g., ESP), that it is being 'driven' on a dynamometer?
'Thx.'
Michael
Yes. But that has been the case for a loooong time. icon_lol.gif icon_wink.gif
Translated on 04-10-2026, 19:45.
Post05-04-2013, 8:36    Subject: Testing: Other Fields & Data Fields. Quote
Unfortunately, I can only provide this from memory, without being able to cite specific sources.
In the early days of digital engine control systems, some manufacturers used test bench identification routines that would switch to specific "maps" with particularly good fuel efficiency and emission values. In normal road use, however, other settings, focused on performance and driving pleasure, were automatically engaged.
It was classified by the KBA(?) as a deliberate fake used for dynamometer tests and was then explicitly prohibited.
Currently, engines are also tuned to achieve low consumption and emission values within the speed and load ranges of the official test cycles, but (importantly!) if someone operates the engine within these parameters in normal road traffic, the engine runs with the same (performance-reducing) parameters as it does on the test bench.
Translated on 04-10-2026, 19:46.
Post05-04-2013, 9:54    Subject: Testing: Other Fields & Data Fields. Quote
Hi.
You mean, for example, the "bumps" that appear at the beginning of the injection process in a Golf 3 TDI engine.
Translated on 04-10-2026, 19:47.
Post05-04-2013, 10:18    Subject: Testing: Other Fields & Data Fields. Quote
dieselmartin wrote:
For example, you're talking about the "humps" at the beginning of the injection of a Golf 3 TDI...
No, those are always there: in normal driving and on the test bench, because the MSA15 doesn't have explicit test cycle recognition.
The G3 was able to implement the fuel-saving ridges without exceeding the critical emission limits during the testing cycle.
Translated on 04-10-2026, 19:48.
Post05-04-2013, 11:19    Subject: Testing: Other Fields & Data Fields. Quote
Okay,
The humps cannot be recognized by a test bench, but they are specialized for it.
But the Münch Mammoth does things like that.
http://www.spiegel.de/spiegel/print/d-27497223.html
"... while approaching at 50 km/h, the system anticipates the test situation and automatically reduces power."
Translated on 04-10-2026, 19:49.
No new posts Other ESP for an AFN Diesel Engine Technology
No new posts Funny License Plates: Unique & Creative Designs On-Board Diagnostics (OBD)
No new posts Golf 4 Headlights: Alternatives & Replacements Transmission, Chassis, Body & Interior
No new posts Vito Partition: Alternatives & Options Transmission, Chassis, Body & Interior
