A6 4G Cornering Light Coding
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post01-04-2013, 11:53    Subject: A6 4G Cornering Light Coding Quote
Hi.
Are there specific contexts in which this encoding (byte 4, bit 1) works, but not in others?
I have two 4G headlights, both with "Xenon plus," which means "straight-beam xenon headlights, WITHOUT a turning function, but WITH all-weather lights."
They both have the same BCM (Baseband Controller Module), the same hardware, and the same software.
One of them (Moni) could be easily programmed with the "turn signal over fog lights" function, while the other (Günther) could also be programmed, but hasn't been.
I changed the "40" in byte 4 to "41".
Moni:
Code:
Adresse 09: Bordnetz (J519)       Labeldatei: 4H0-907-063.clb
   Teilenummer SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Bauteil: BCM1 2.0      H12 0100
   Revision: 20012002    Seriennummer: 00000000971590
   Codierung: 2600201040749F608481008300001D0CCF9C87082E090101000008602100
   Betriebsnr.: WSC 02391 785 00200
   VCID: 6DDA59F6B48ADF1
   Subsystem 1 - Teilenummer SW: 4G1 955 119     HW: 4G8 955 119
   Bauteil: WWS57X 110615  H35 0051
   Codierung: 0045F7
   Subsystem 2 - Teilenummer SW: 8K0 955 559     HW: 8K0 955 559   Labeldatei: RKS\8K0-955-559.CLB
   Bauteil: RLS  H04 0003
   Codierung: 02512B
   Subsystem 3 - Teilenummer SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Bauteil: E1 - LDS  H07 0044
   Subsystem 4 - Teilenummer SW: 4H0 907 658     HW: 4H0 907 658
   Bauteil: AQ_Hum_Sensor  H02 0002
Günther:
Code:
   Revision: 20012002    Seriennummer: 00000001097612
   Codierung: 2600201040349F608C81008380001D0CCF9C830826090101000008602100
   VCID: 6DDA59F6B4EA8E70FAA
   Bauteil: WWS57X 110522  H35 0051
   Codierung: 0045F7
   Codierung: 02512B
I can provide complete auto scans, but icon_wink.gif it would make this very long.
Post01-04-2013, 15:58    Subject: A6 4G Cornering Light Coding Quote
2600201040749F608481008300001D0CCF9C87082E090101000008602100 != 2600201040349F608C81008380001D0CCF9C830826090101000008602100
Therefore, "identical" is not the same. icon_wink.gif What would be interesting are the differences...
Post01-04-2013, 20:56    Subject: A6 4G Cornering Light Coding Quote
Okay.
Then I need to clarify what I meant by "equal," because I meant:
Code:
and also that "here", because I still need to go to one of the trekkers icon_wink.gif.
Post28-04-2013, 15:44    Subject: A6 4G Cornering Light Coding Quote
"Identical" is therefore not the same. icon_wink.gif The differences would be interesting...
Byte 5: Changing the value from 74 to 34 indicates that FLA is installed (and has more instances than necessary, where applicable).
Byte 8, changing from 84 to 8C, indicates the air suspension system (which is present where it should be, but not where it's missing).
Byte 12: Unfortunately, VCDS does not have information on this.
Byte 18: Unfortunately, VCDS does not have information on this.
Byte 20: Unfortunately, VCDS does not have information on this.
No new posts Motorsteuergerät Golf IV kodieren On-Board Diagnostics (OBD)
No new posts Tire Pressure Monitor: Retrofit & Coding Transmission, Chassis, Body & Interior
No new posts Which Steuergeräte encode for AHK, Audi A4 B7?? On-Board Diagnostics (OBD)
No new posts Abbiegelicht symmetrisch ? Transmission, Chassis, Body & Interior
