"Relay 109/219" for the Passat 3C BLS
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vwSchrauber
Post02-05-2013, 9:37    Subject: "Relay 109/219" for the Passat 3C BLS Quote
"Where is the relay for the voltage supply from the engine control unit (ECU) located in a 2006 3C vehicle with a BLS engine?" We have a vehicle that is repeatedly failing. The engine control unit (ECU) has no fault codes stored. However, the fault memory modules for ABS, instrument cluster, steering, etc., all show an error message that essentially translates to "no communication with the engine control unit."
Post02-05-2013, 11:37    Subject: "Relay 109/219" for the Passat 3C BLS Quote
Does that even still exist?
Because then it would only start to decay after the initial sound, but I don't hear anything after that.
Post02-05-2013, 11:50    Subject: "Relay 109/219" for the Passat 3C BLS Quote
Where is the relay for the voltage supply from the engine control unit (ECU) located in a 2006 3C model with a BLS engine? We have a vehicle that is repeatedly failing; the engine control unit's fault memory is empty
It should be located in the engine compartment, on the left side, inside the electrical box. The fuse would be SB14.
The fuses SB16, 20, 23, and 24 are also connected to the same terminal block as SB14. These should also not have any electrical current flowing through them if they are defective.
Before the motor control unit (STG), there should be a junction point in the cable harness (1 to 3 wires, color red/green) that connects to terminals 3, 5, and 6 on the STG.
Information provided without guarantee.
Post02-05-2013, 12:55    Subject: "Relay 109/219" for the Passat 3C BLS Quote
Ah, OK.
That will probably coincide with the timing of the throttle valve adjustment... and it will be louder.
vwSchrauber
Post06-05-2013, 11:15    Subject: "Relay 109/219" for the Passat 3C BLS Quote
Thank you, we have now checked... unfortunately, the engine control unit (ECU) is defective icon_sad.gif.
Post06-05-2013, 13:26    Subject: "Relay 109/219" for the Passat 3C BLS Quote
And please let me know if the error has been fixed.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Relay Clicking After Start / Cold Start Problem Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Passat 3B AFN: Lack of Low-End Power (Long) Diesel Engine Technology
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
