Herbert wrote: |
Could you please mark the values for "spread" and "lag" in the protocol?
I don't believe it's 7 degrees of rake.
Herbert |
I don't understand how I'm supposed to highlight it - do you mean "underline"?
Is the form/protocol not displaying correctly for you?
In the middle column are the VW specifications/target values (the heading above the column is at the very top).
The reading shows a value of 7°47' +/- 0°30' for the "nachlauf" (which likely refers to a specific parameter or setting).
That probably means that, according to VW's specifications, a reading between 7°17' and 8°17' is acceptable.
Now I have 7°51' on the left and 7°49' on the right - I think those are very good, well-centered, and equal values.
In the previous three surveys, I always had readings around 8°10' and 8°20', and it was always stated that nothing could be done about it because 8°20' is outside the specified range.
But since it's better to have too much than not enough, I always made sure to leave some extra (even though it wasn't really a big deal).
But, as I mentioned, we'll revisit the matter next week.
Then I'll include the latest survey report.
