Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check
Kitwing
Post31-01-2013, 20:31    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Hello everyone,
My wife recently got a new car.
Golf 6 TSI with 160 horsepower.
Common issues with the 1.4L TSI engine include timing chain problems.
As luck would have it, the car is now stalling when starting, and then making noises.
I suspect the chain is rattling.
"Wouldn't you be able to tell, based on the valve timing, that the chain is already stretched?"
Thomas
A6 Allroad BJ 2016 3.0 TDI
Kitwing
Post31-01-2013, 20:37    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
I just remembered that there are also known issues with the camshaft adjuster.
Perhaps VCDS can also assist me with this task.
However, I would need your support to implement this.
Okay, so which material safety data sheets (MSDS) need to be reviewed, and which values must not be exceeded?
Thank you.
Post31-01-2013, 20:38    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
What is the VAG part number for the engine control unit? (Or, what is the part number that can be found using a vehicle diagnostic scan tool?)
Kitwing
Post31-01-2013, 20:41    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Saturday, January 26, 2013, 4:26:11 PM: 15488
VCDS Version: RKS 11.11.5
Data as of: 20130111.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56
Vehicle Identification Number: WVWZZZ1KZ9P473354
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: Error 0010.
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000
56-Radio -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine (CAV)
Label file: RKS\03C-906-027-CAV.clb
Part number SW: 03C 906 027 BS, HW: 03C 906 027 F.
Part number: MED17.5.5 1676
Revision: L1H08--- Serial number:
Encoding: 0000072
Operating number: WSC 50237 127 84134
VCID: 73EEB3561289A8802CE
No error codes found.
Readiness: 0000 0000
Address 03: Brakes (-----)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AE, Hardware: 1K0 907 379 AE.
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Encoding: 143B600D092900FD280E06E9901D00403400
Operating number: WSC 00028 028 00001
VCID: 75EA8D4EDCFDB6B002A
Address 08: Climate Control/Heating (J255)
Label file: RKS\5K0-907-044.clb
Part number SW: 5K0 907 044 AK, Part number HW: 5K0 907 044 AK.
Component: Climatronic 130 0305
Revision: 00002001
Encoding: 0000000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW36.rod
VCID: 74ECB04ADF87AFB8354
Address 09: Body Control (J519)
Label file: RKS\1K0-937-08x-09.clb
Part number SW: 1K0 937 086 Part number HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Encoding: 40180A3A98251A0040080080500081E445010088724D8D60648000000000
VCID: EDDA252E34ADFE707AA
Subsystem 1 - Part number: 1K1 955 119 E. Label file: RKS\1KX-955-119.CLB.
Part: Wiper 13030 21 0501
Encoding: 009795
9 errors found:
00924 - Relay for headlight cleaning system (J39)
009 - Short circuit to ground.
Environmental conditions:
Error status: 01101001
Error priority: 4
Error frequency: 1
Lost Count: 1
Mileage: 67433 km
Time: 0
Date: 2026.14.28
Time: 13:40:22
Class 15, Entry.
Voltage: 12.05 V
one
one
Size 50, SOLD OUT.
text
from
text
from
00446 - Function impairment due to undervoltage.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 6
Error frequency: 254
Lost Count: 254
Mileage: 67433 km
Time: 0
Date: 2026.14.28
Time: 13:44:45
Class 15, Entry.
Voltage: 11.70 V
one
one
Size 50, SOLD OUT.
text
from
one
00532 - Power supply voltage.
Error priority: 4
Error frequency: 1
Lost Count: 97
Mileage: 71,465 km
Time: 0
Date: 2028.14.16
Time: 07:30:27
Class 15, Entry.
Voltage: 14.50 V
one
one
Size 50, SOLD OUT.
text
from
text
from
Error priority: 4
Error frequency: 1
Lost Count: 164
Mileage: 74583 km
Time: 0
Date: 2029.14.31
Time: 09:47:57
Class 15, Entry.
Voltage: 14.05 V
one
one
Size 50, SOLD OUT.
text
from
text
from
Error priority: 4
Error frequency: 1
Lost Count: 174
Mileage: 84,728 km
Time: 0
Date: 2100.14.29
Time: 06:02:51
Class 15, Entry.
Voltage: 14.00 V
one
one
Size 50, SOLD OUT.
text
from
text
from
Error priority: 4
Error frequency: 1
Lost Count: 122
Mileage: 83,857 km
Time: 0
Date: 2099.14.19
Time: 07:49:17
Class 15, Entry.
Voltage: 10.55 V
one
one
Size 50, SOLD OUT.
text
from
one
Error priority: 4
Error frequency: 1
Lost Count: 84
Mileage: 81,397 km
Time: 0
Date: 2098.14.20
Time: 20:18:27
Class 15, Entry.
Voltage: 14.00 V
one
one
Size 50, SOLD OUT.
text
from
text
from
00907 - Load Management Procedure.
text
000 - -
Error status: 01100000
Error priority: 6
Error frequency: 1
Lost Count: 214
Mileage: 86,050 km
Time: 0
Date: 2106.14.31
Time: 16:21:22
Class 15, Entry.
Voltage: 11.35 V
one
one
Size 50, SOLD OUT.
text
from
text
from
00978 - Headlight assembly, low beam, left side (M29)
010 - Interruption/Short circuit after positive - Intermittent.
Error status: 00101010
Error priority: 1.
Error frequency: 16
Lost Count: 253
Mileage: 85980 km
Time: 0
Date: 2024.14.21 (or 2024. June 14)
Time: 14:03:42
Class 15, Entry.
Voltage: 14.25 V
one
one
Size 50, SOLD OUT.
text
from
one
Address 10: Parking Assist 2 (J791) Label file: RKS\1T0-919-475.clb
Part number SW: 1T0 919 475 D, HW: 1T0 919 475.
Part: PARKING ASSIST PLA H07 0012
Revision: -------- Serial Number: 45230902002466
Encoding: 10000A
VCID: 3C7C586ABF5727F83D4
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 5K0 959 655 HW: 5K0 959 655
Part number: Airbag VW10, 033 0604.
Serial number: 003C2D0A3GK-
Encoding: 00003135
Operating number: WSC 00028 028 00011
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: F7F607464EF144A0906
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V U01 ----
Serial number: 39092146ZZZZZZZZZZZZ
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Front Passenger, U01 ----
Serial number: 40416145ZZZZZZZZZZZZ
Rear side airbag crash sensor (driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 1C45192DZZZZZZZZZZZZ
Crash sensor for rear side airbag, passenger side:
Component: S. Sensor, Front, Right --- ----
Serial number: 08281E12ZZZZZZZZZZZZ
Address 16: Steering wheel
Label file: RKS\1K0-953-549-MY9.lbl
Part number SW: 1K0 953 549 CQ
Hardware number: 1K0 953 549 CQ
Part: J0527 853 0111
Encoding: 0000004
VCID: 830E6396C2291800BCE
Address 17: Combination instrument (J285)
Label file: RKS\5K0-920-xxx-17.clb
Part number SW: 5K0 920 870 B, HW: 5K0 920 870 B.
Component: COMBINATION H21 0030
Serial number: 00000000000000
Encoding: 170F00
Operating number: WSC 00028 028 00025
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2C5C682A4737B778AD4
Address 19: CAN-Gateway Label file: RKS\1K0-907-530-V4.clb
Part number SW: 1K0 907 530 S, HW: 1K0 907 951.
Component: J533, Gateway, H07 0071.
Revision: H07 01 Serial number: 140309F2001899
Encoding: E9A01F06000212000000
VCID: 37764746467104A0D06
Address 25: Immobilizer (J334)
Label file: RKS\5K0-920-xxx-25.clb
Component: IMMO H21 0030
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 2E: Media Player 3 (J650) Label file: RKS\5N0-035-342.lbl
Part number SW: 5N0 035 342 B, Hardware: 5N0 035 342 B.
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial Number: 7667387260
Encoding: 010000
VCID: 26489A0251DB8D287B0
Address 42: Door electronics. Driver Label file: RKS\1K0-959-701-MIN3.lbl
Part number SW: 1K0 959 701 AF, HW: 1K0 959 701 AF.
Part: Door seal 008 2043
Encoding: 0000052
VCID: 72E0B6526D93A188278
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K0 909 144 E
Component: EPS_ZFLS, Size 69 2501
Revision: 00H15000
VCID: 2C5C682A8F37B778AD4
Address 52: Door electric, passenger side. Label file: RKS\1K0-959-702-MAX3.lbl
Part number SW: 1K0 959 702 AG HW: 1K0 959 702 AG
Encoding: 0000308
VCID: 74ECB04A1787AFB8354
Address 56: Radio (J503) Label file: RKS\5M0-035-1xx-56.clb
Part number SW: 1K0 035 186 AA, Hardware: 1K0 035 186 AA.
Part: Radio RCD310, part number 012 0029.
Revision: 00000000 Serial Number: VWZ1Z2I6087542
Encoding: 0100040004
VCID: 65CADD0E6C5D4630B2A
End.
Kitwing
Post01-02-2013, 19:46    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Nobody has any ideas.
Post01-02-2013, 22:32    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
No one has an idea
But -- check the valve timing, inspect the timing chain.
Can it be done with VCDS? But what's the point if the valve timing might not have been perfectly adjusted in the first place?
If, for example, the timing is 2 degrees too advanced, and the chain had stretched by the same amount,
Would you be at a 0-degree offset? And then -- you're just as smart as you were before.
Post03-02-2013, 19:43    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
I think, as Autoservice suggests, the only thing that might help is to disconnect it, as adjusting the target/actual values for the camshaft timing probably won't make a difference in this case.
It will likely still adjust with a longer chain, and if the absolute position is also taken into account (which I don't know), then comparison values from a different vehicle would be needed.
Kitwing
Post03-02-2013, 20:27    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Okay, thanks for the information!
Could a faulty camshaft timing solenoid be detected using VCDS?
Post04-02-2013, 9:29    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Kitwing wrote:
Would a faulty camshaft timing solenoid be detectable in any way using VCDS?
Yes, in that case, the actual value would not be able to follow the target value of the variable valve timing system.
Kitwing
Post07-02-2013, 7:45    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
In which data medium can I extract this information?
Thank you for your help.
PS: Are the voltage supply errors reported in the log normal?
Sometimes, according to the logs, these errors also appear even at voltages of 14.xx volts.
Post07-02-2013, 10:49    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Since the body control module seems to be affected only by "undervoltage," you should check its power supply, connector, cables, and fuse(s).
Post07-02-2013, 12:00    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
There are likely two variations for the engine version with the "vertical" oil filter.
Depending on the configuration and the use of the incorrect filter, it may cause oil pressure problems and chain rattling. The same applies to [something else, implied by "n."]. Statement regarding icon_lol.gif if the "2. (old)" sealing ring is left in place or forgotten during the oil filter housing replacement.
Post07-02-2013, 12:47    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
Kitwing wrote:
Which MWB (Material Safety Data Sheet) can I find this information in?
Click on the blue name of the label file in the measurement blocks in the upper left corner, and then search for "camshaft adjustment."
Kitwing
Post18-04-2013, 8:31    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
So, to keep you updated:
I had the timing chain replaced, as well as the water pump.
VW paid 100% of the labor costs and contributed 30% towards the parts.
After running smoothly for a month, the car has encountered a new problem again this morning.
During a cold start, the engine speed increases up to 2000 rpm.
Let's see what other surprises this vehicle has in store for me.
Thank you for your support.
Post18-04-2013, 9:59    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
If the engine control unit's fault memory is empty, check the coolant temperature sensor.
Kitwing
Post11-06-2013, 13:37    Subject: Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Quote
I checked the sensor and found no discrepancies.
The problem has hardly occurred at all for about 4-6 weeks.
I noticed that the SW version displayed in the MSG is very old, and I was wondering if there's a way to update it myself.
The friendly person wants 75-100 euros for it.
No new posts Ignition Coil Testing: How to Check & Diagnose Troubleshooting & Guides
No new posts TDI 1.9L Injection Pump: Testing & Adjustment Troubleshooting & Guides
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Check Timing for VW/Audi 3.0 TDI Engines Diesel Engine Technology
No new posts Check valve timing 2.0 CR with VCDS On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. AFN Engine: 160HP, 400Nm - Safe or Risky? Diesel Engine Technology
No new posts Golf 6, BCM, and Kurven Xenon Transmission, Chassis, Body & Interior
