TTaurus
30-06-2013, 22:07 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
I would like to read the error codes from an A4 B7.
Unfortunately, neither the engine control unit nor the brake control unit is responding, while all other control units are working fine.
Best regards, TTaurus.
Translated on 22-10-2026, 18:50.
Autoservice Profi-Schrauber
30-06-2013, 22:29 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
Which version of VCDS are you using? As far as I know, it only works with the KKL+CAN interface. LG, Onkel BM
Translated on 22-10-2026, 18:51.
01-07-2013, 5:55 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
Please post the Autoscan results.
Profile PM WWW Garage |
TTaurus
01-07-2013, 12:28 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
Hello, I must admit I only have the Micro-CAN and a self-soldered K-line. The A4 has Xenon headlights and was manufactured in 2006. Would I need to connect the Micro-CAN to the engine control unit? Can this be done with VCDS-Lite, or do I need the KKL+CAN interface? Thanks and regards, TTaurus.
TTaurus
01-07-2013, 16:20 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
But precisely from this, it becomes clear that the HEX-USB is sufficient until 2004, and that starting in 2005, CAN functionality is also required!
Is a CAN interface or an additional K-line (KKL) now required to access the engine control unit (ECU)?
Would VCDS-Lite be sufficient?
Translated on 22-10-2026, 18:53.
01-07-2013, 18:51 Subject: A4 B7 ECU Not Responding: Troubleshooting Guide |
Quote: | for all VAG vehicles based on the Golf 5/6 platformwith CAN.
Attention, this system is onlyintendedfor the following vehicle types from the VAG group, for which all control units can be accessed via CAN bus: ... <Long>[/color].
Reading helps... see also the vehicle list.
[/b]But it is precisely from that that it becomes clear... |
No. Even if you claim the opposite of what is clearly stated in the list, it will not become true or work for that reason... Quote: |
The following is required for the 2006 Audi A4 B7:
Best regards, Rainer.:roll:http://shop.dieselschrauber.de/vcds-obd2-profi-diagnose-kkl-can-p-46.php
Translated on 22-10-2026, 18:54.
