menzinger68
Joined: 02/05/2011 Posts: 28 Karma: +0 / -0 Location: Wien
10-07-2013, 7:52 Subject: Completely disable consumer functionality |
I'm frustrated that the battery keeps draining because I often leave some devices turned on when I lock the car.
Is it possible to configure the vehicle's electrical system in my Audi B4 so that when the car is locked, all consumers, including the parking light, are completely turned off?
Thomas.
Audi A4 Avant, 2,5 TDI V6 , BJ 1999, Motor AFN
Getriebe DAJ DEY
10-07-2013, 8:33 Subject: Completely disable consumer functionality |
Quote: | | Audi A4 Avant, 2.5 TDI V6, manufactured in 1999 |
No, in that car, the lighting and other functions are not yet controlled by a central control unit (ECU). Therefore, when the corresponding switch is closed, the circuit is active.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
10-07-2013, 10:37 Subject: Completely disable consumer functionality |
Quote: | | Is it possible to configure the on-board network of my Audi B4 so that when the car is locked, all consumers, including the parking light, are completely switched off? |
That would not be legal. It's also not much use if you forget to  .
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
10-07-2013, 10:39 Subject: Completely disable consumer functionality |
Possibly, an additional warning buzzer could be installed that beeps when the ignition is off and the lights are on.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
DieselBĂ€r30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂŒnchen & Passau
10-07-2013, 14:20 Subject: Completely disable consumer functionality |
Hello everyone!
A warning buzzer is installed and reliably goes off when the parking/boundary light is on, the ignition key is removed, AND the driver's door is open.
In the latter case, the door lock, or more specifically, its microswitch, is usually broken, and as a result, the horn will no longer work.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
