Engine temporarily maintains RPM, automatically increases throttle (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Fabia.S
Post09-07-2013, 23:03    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Background:
Today, I replaced all the brake hoses on my Fabia, including the entire front brake system. Make sure the wheel bearings are properly maintained, and always keep the brake fluid reservoir sufficiently filled and never let it run empty.
After that, in this self-help workshop, which also operates as a free workshop, the brake system was bled, and additionally, the brake fluid in the clutch slave cylinder was replaced. (An electric brake bleeding device was used, powered by the vehicle's electrical system).
Nothing else has been done to the Fabia.
The problem is that when downshifting and engaging the clutch, there's a very brief, sudden, and unexpected surge of acceleration.
When the accelerator pedal is completely released while maintaining a constant speed, this occurs for 4-5 seconds.
Despite this, the throttle was kept consistently steady. Then, abruptly, the fuel injection is reduced to zero until the idle control is engaged. The idle speed control is otherwise unremarkable.
Now the question is, where does the error lie, where does it come from, and how would one go about finding it?
As I said, nothing else has been changed, and the engine was running without any problems.
Fabia 1.9 Combi, Bj. 2001,ATD Euro 3
Spritspartuning aus dem Shop,Schlechtwegefahrwerk, 285000 km
Post10-07-2013, 0:26    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
What does the error log say?
Are any cables torn or damaged?
Okay, hier ist die Übersetzung:
"Otherwise, create an Autoscan and post it here."
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Karma: +1102 / -0   Thank you, like it!
Post10-07-2013, 5:18    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Spontaneously, I would also suggest that the clutch pedal switch could be a likely culprit. Possibly just lost it?
Post10-07-2013, 9:29    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Hutfahrer wrote:
Spontaneously, I would also think that the clutch pedal switch could be a likely candidate. Possibly just lost it?
It can be checked in VCDS within the corresponding measurement block.
Post10-07-2013, 10:00    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
...and/or checked or repaired by directly accessing the area with a specific tool or method.
provided that the switch is not mechanically or electrically defective.
I learned about the function of the clutch pedal switch from you, by the way. [img][/img]http://www.radio-dx.eu/Sebastian/Smilies/dankeschoen.gif{MARKER}
Fabia.S
Post10-07-2013, 15:28    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
I was able to quickly read out two error messages.
Combination instrument.
01197 Data bus drive, incorrect software version 35-00--
and errors in the ABS/ASR system.
00597 - Different wheel speed pulse signals 35-10---
The two rear wheel sensors have the same difference in reading compared to the front sensors. At approximately 14 km/h in the front, 16 km/h is displayed in the rear.
I experienced the error during the drive home, but it didn't reappear after the engine was turned off.
As of today, during this current trip, both errors have reappeared.
I can't imagine that such an error could occur simply by swapping the rear wheels, which still had almost full tread, with the worn-out front wheels.
Since I started using this type of tire in the same size as before, and within the allowed size of 185/60 R14, the speedometer shows a lower speed of approximately 3 km/h compared to the previous tires.
My current assumption is that the ABS (Anti-lock Braking System) tolerance has now been exceeded.
So, we need to switch the wheels around first.
I'm also going to re-check the clutch pedal switch.
Fabia.S
Post11-07-2013, 14:49    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Okay,
Thank you for the information about the clutch pedal switch.
He was the one. The errors have been fixed, and the Fabia is running as it should.
Post11-07-2013, 15:25    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Okay - and thank you for the feedback icon_wink.gif.
Post11-07-2013, 15:59    Subject: Engine temporarily maintains RPM, automatically increases throttle Quote
Great.
Was it a loose connection or an electrical defect?
Because, once a puzzle is solved, you are officially not allowed to use it again.
//edit: Since he can no longer reply here after the post was moved to the tips section, the switch was electrically defective.
Ratings - Engine temporarily maintains RPM, automatically increases throttle
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MJ 2001: AC Issues, Intermittent Function. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Revs Briefly on Its Own? Diesel Engine Technology
No new posts Motor loses power at a certain RPM Diesel Engine Technology
No new posts Starter Motor: RPM to Start Engine On-Board Diagnostics (OBD)
No new posts TDI 1.9 Engine: Stalling, Surging, or Running Rough? Diesel Engine Technology
