Check DPF fill level
Hitcher
Post11-07-2013, 19:51    Subject: Check DPF fill level Quote
Is there a way to "check" the ash mass using the pressure differential sensor?
I wanted to check with my mechanic if the oil consumption reading (0.17 liters per 1000 km at 235,000 km) that the dealership gave me is reasonable, because the car seems sluggish again.
`01 -`05 Corrado TDI, so fährt das richtig
`05 -`09 A4 B5 AJM
`09 - ... A4 B7 ASB
Translated on 17-07-2026, 6:46.
Post11-07-2013, 20:20    Subject: Check DPF fill level Quote
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Translated on 17-07-2026, 6:47.
Hitcher
Post11-07-2013, 21:37    Subject: Check DPF fill level Quote
Thank you icon_exclaim.gif.
`05 -`09 A4 B5 AJM
`09 - ... A4 B7 ASB
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Adjustment: Check and Calibration Diesel Engine Technology
No new posts How to inspect the tie rods on a G IV. Transmission, Chassis, Body & Interior
No new posts Check two-mass flywheel. Upload
No new posts Check VP37 Diesel Engine Technology
