Ford Focus 1.6 116HP VCT, 2004, poor starting performance
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post03-09-2011, 21:20    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
I'm having a small problem with my parents' car.
"I have a Ford Focus, manufactured in 2004. When I try to start it, it doesn't turn over at all on the first attempt, but usually starts immediately on the second attempt."
Whether it's warm or cold weather, sometimes it just doesn't start at all.
Today, I had to try about 10 times before he finally agreed.
What I've also noticed is that the engine sometimes only runs on 3 cylinders immediately after starting, but then it catches and runs on all cylinders after about 5 seconds.
I was at an independent workshop, but the error memory from the MSTG is empty icon_rolleyes.gif.
Does anyone have any ideas about that?
Greetings.
Translated on 09-07-2026, 4:37.
mogli
Karma-Bildequivalent
Karma: +8 / -24   Thank you, like it!
Post04-09-2011, 2:50    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Hi.
Candles, oil change interval, which oil, mileage.
Rarely does anything get fixed just by looking at the error logs.
Best regards, Lorenz.
Translated on 09-07-2026, 4:38.
klahaui
Avatar-klahaui
Post04-09-2011, 12:03    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
New candles, no improvement.
After interval display, 5W30.
80,000 km
It all started after the last inspection at the Ford workshop.
Post04-09-2011, 12:26    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
How about consumption, performance, stuttering, or other issues?
Or is it really just the starting behavior?
Translated on 09-07-2026, 4:39.
klahaui
Avatar-klahaui
Post04-09-2011, 13:04    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Well, consumption is kind of a tricky thing icon_lol.gif.
"When I drive, I get around 8 liters per 100 kilometers. My father needs about 10-11 liters. (On the highway, it's 7-8 liters)."
He also complains about the lack of power, but I can't really complain about that. (It's normal for a 1.6 station wagon.) It also reaches its top speed.
The LMM (likely referring to a Lambda sensor or similar component) was also replaced six months ago because it wasn't providing any readings at that time.
He doesn't experience any stuttering, and the throttle response is very good.
Translated on 09-07-2026, 4:40.
Karma: +583 / -0   Thank you, like it!
Post04-09-2011, 21:06    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Hi!
Ford engines often require a very specific type of motor oil.
If it's a Zetec engine (as indicated), then you should use the appropriate engine oil for that type of engine.
It's also not more expensive than regular 5W-30.
It is a special oil for Ford and Jaguar vehicles.
It is usually designated as 5W-30.
I have quite a few similar cars in my care, so there aren't usually any problems.
"I've actually been using the correct oil in that vehicle for years."
Otherwise, there are often problems with the ignition coils in cars.
That's a known issue.
It doesn't quite fit with the error pattern you're seeing.
Translated on 09-07-2026, 4:41.
klahaui
Avatar-klahaui
Post04-09-2011, 21:17    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Yes, I've also experienced that problem with using the wrong oil.
It was then replaced relatively quickly by the Ford workshop.
The funny thing is, sometimes it just doesn't start.
My initial suspicion was that one of the ESD seals wasn't properly sealed.
If I only turn the ignition on, doesn't the fuel pre-pump or something similar build up a certain amount of pressure?
It still doesn't start easily. I really have to let the starter motor run for a short time before it finally starts on the second attempt.
Translated on 09-07-2026, 4:43.
chriskross
Post27-09-2011, 21:02    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Hi, I also had a similar problem with a Focus 1.6L Zetec engine that had a dual-spark ignition coil. Those are a real weak point. I would suggest trying to replace the ignition coil as a test; it's not that expensive.
Best, Chris.
A6 AFB
A6 BRE DPF
klahaui
Avatar-klahaui
Post22-01-2012, 19:59    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Here's a little feedback.
My parents called me and asked what kind of oil they could add because they noticed some was missing.
I sent it to the Ford dealership where it was originally purchased because I didn't have time to inspect it myself.
The workshop found that the oil in the oil pan had already formed clumps.
They immediately had the oil changed, and sure enough, the car has been starting right up ever since. Even now, when it's minus 5 degrees Celsius, and even if it sits for three days.
How can this be?
The bigger question for me, however, is more about why the oil is clumping after just one year, 3 months, and 16,000 km icon_question.gif.
Greetings.
Translated on 09-07-2026, 4:45.
klahaui
Avatar-klahaui
Post04-08-2013, 12:03    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
Error found:
The pump in the tank has a check valve that is defective.
Unfortunately, it cannot be replaced individually, and a new pump costs €480.
Solution: A check valve from the accessories was installed in the fuel line, and since then, there have been no more starting problems.
Translated on 09-07-2026, 4:46.
Post04-08-2013, 14:30    Subject: Ford Focus 1.6 116HP VCT, 2004, poor starting performance Quote
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Heckklappe VW Caddy Mj.2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: Smoking & Starting Problems Upload
No new posts Very poor starting behavior for gasoline engines! On-Board Diagnostics (OBD)
No new posts Bubbles in the line / poor starting... Diesel Engine Technology
No new posts schlechtes Fahrverhalten & starke Spurrillenempfindlichk Transmission, Chassis, Body & Interior
