Joined: 04/12/2002 Posts: 18115 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
28-08-2013, 12:51 Subject: VW Crafter, Year 2012/2013, High Standby Current |
Due to a software error in the ignition starter switch, some vehicles may experience increased noise in the vehicle's electrical system.
This leads to a discharged battery after some time of inactivity.
If the Crafter's resting current is unusually high, and no other cause can be identified, it should be checked whether the starting/ignition switch is the cause.
Solution: Replace the ignition switch and reprogram all keys (Service action!).
