P046C Error: Troubleshooting & Fixes
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post28-08-2013, 7:10    Subject: P046C Error: Troubleshooting & Fixes Quote
Hello everyone, and greetings to all.
G6,1 K, Engine CAY 1.6, 77KW, 6/2010
While troubleshooting the fault with the emergency mode, I haven't been able to find the root cause.
7563 AGR sensor, implausible signal. Intermittent. Is this an electrical sensor in the AGR valve?
There is a TPi number 2029086. What does it say?
Does anyone have access?
Thank you, Klaus.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 23-09-2026, 3:21.
Post28-08-2013, 9:03    Subject: P046C Error: Troubleshooting & Fixes Quote
Is that an electrical sensor in the EGR valve?
Should be - Comparison of the desired and actual AGR (Automatic Gearbox) position, or for monitoring the actual AGR position.
Translated on 23-09-2026, 3:22.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post28-08-2013, 9:27    Subject: P046C Error: Troubleshooting & Fixes Quote
Hello, thank you, Uncle BM icon_smile.gif.
Okay, I've found out that to remove the EGR valve and inspect it for carbon buildup on the 1.6-liter engine (where it's located at the rear), you need to drain the engine oil, remove the DPF (Diesel Particulate Filter), and replace the entire EGR cooler assembly.
It took 4 hours of work just to diagnose the problem, and then they didn't bother to fix it properly, they just replaced the part. Now I'm going to file a goodwill request. Let's see, the engine has 54,000 km on it and it's only 3 years old, so hopefully they'll cover something.
Translated on 23-09-2026, 3:23.
bloesch
Post29-08-2013, 7:45    Subject: P046C Error: Troubleshooting & Fixes Quote
I don't have the technical specifications in front of me, but I believe this involves only updating the engine control unit (ECU).
BTW: The day before yesterday, we still had 4 AGR coolers in stock for the 1.6 engine icon_rolleyes.gif.
Translated on 23-09-2026, 3:24.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post29-08-2013, 8:46    Subject: P046C Error: Troubleshooting & Fixes Quote
Hello, no, this involves guided troubleshooting, then the engine is lowered, the EGR block with the K-cooler is removed, and then it will be inspected and, if necessary, replaced.
But if all of this is removed, the cleaned EGR valve probably won't be reinstalled.
The cost is reportedly around 700 euros. I heard that maybe something might be possible after 3 years through a goodwill gesture.
The inventory management suggests a quality issue.
Thank you for your feedback.
Translated on 23-09-2026, 3:25.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Error 65535: External Pressure & Emergency Mode On-Board Diagnostics (OBD)
No new posts Audi A8: Fuel Injection Error - Limp Mode? On-Board Diagnostics (OBD)
No new posts Golf AJM Error 17958: Troubleshooting & Photos On-Board Diagnostics (OBD)
No new posts ACV Emergency Stop Diesel Engine Technology
