snowman24 Guest
30-08-2013, 16:31 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
Hello everyone,
I have a question for you all, as my current VW Touareg V8 (4.2L - AXQ) has been driving a bit strangely lately.
The automatic transmission shifts up much earlier than before - almost as if the engine is no longer producing enough power/torque. In the highest gear (6th gear) on the highway, you can feel a noticeable jerk when trying to accelerate further from 180 km/h.
Of course, there's nothing in the error memory.
With LPG, I switch to it at the latest at 4500 RPM or 124 mph (200 km/h) to prevent any damage to the engine, and also when using the kick-down function.
A local repair shop said:
'You have two mass airflow sensors (MAF sensors) installed and they already have 160,000 km on them. Are those still the original MAF sensors?'
Yes, they are.
I've had to replace those things very frequently in my diesel vehicles.
While I was just doing a little searching online to see if LLMs (Large Language Models) can also fail in gasoline engines, I found many entries – especially this one: 'Automatic transmission shifts back into lower gear earlier...'
Could you tell me which module I need to access in order to see the values?
Sure, here's the translation:
'Thank you in advance.'
Greetings.
Marcus.
Translated on 12-07-2026, 18:43.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
30-08-2013, 16:39 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
It would also be interesting to know the coolant temperature, as this value is also transmitted to the central monitoring system (MSTG).
The error might be hidden here as well.
VCDS should actually display the mass airflow readings if you access the relevant control module.
Best regards, Kaum macht man es richtig, funktioniert es!
Translated on 12-07-2026, 18:46.
Profile PM Garage |
snowman24 Guest
30-08-2013, 16:43 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
Thank you for the information. The coolant values are correct and, as far as I can tell, match the actual values.
I see the air masses, yes - but with diesel engines, there were definitely 'IS' and 'SHOULD' values, or am I misremembering something?  [/u]
Translated on 12-07-2026, 18:47.
Joined: 04/12/2002 Posts: 18130 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
30-08-2013, 17:22 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
Please always include the Autoscan results in these cases.
Profile PM WWW Garage |
snowman24 Guest
05-09-2013, 13:32 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
Brief feedback.
I have now replaced the LMMs after reviewing the production data for the installed LMMs.
KW10/2005 and KW 13/2005.
So, those items have never been exchanged.
Final result:
Noticeably more power, significantly improved responsiveness.
The automatic transmission shifts up much earlier, and according to the onboard computer, the fuel consumption is...
The fuel consumption has decreased from approximately 16-18 liters per 100 kilometers at a speed of 100 km/h to about 12 liters per 100 kilometers.
Let's see how this affects a full tank of gas.
Thank you for your help.
Greetings.
Marcus.
Translated on 12-07-2026, 18:48.
05-09-2013, 15:14 Subject: Ask the LLM about gasoline engines - which maintenance work is required? |
Okay, good to hear that everything is going well.
Without the specific VAG part number for each control unit, it is very tedious to find descriptions of those control units. It definitely takes longer than simply browsing through a few measured values.
Please remember to include the Autoscan results in your submissions going forward.
Translated on 12-07-2026, 18:50.
