Benni Blaumann
Joined: 11/19/2005 Posts: 302 Karma: +15 / -0 Location: Braunschweig
27-02-2013, 11:14 Subject: |
I know, I've only had the car for 1.5 years, but I realized too late that it was low on coolant, and by then it was already too late to prevent damage.
In our family, batteries typically last around 9 years, and even longer, up to 11 years in the Škoda. We replace them proactively to prevent anyone, especially Grandma or Mom, from getting stranded somewhere.
According to the acid test, my battery had acceptable values for 5 cells, but unfortunately, one cell was completely dead, and there's nothing you can do about that.
But that's going off-topic. Batteries seem to be a never-ending story when you start looking into them.
I was surprised that the "no name" battery (71Ah) felt several kilograms lighter than the Moll battery (70Ah).
Translated on 21-07-2026, 6:49.
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
27-02-2013, 11:38 Subject: |
Hi Benni!
Benni wrote: | ... According to the acid-base test, my Moll had acceptable values for 5 chambers, but unfortunately, one cell was closed, and there's nothing you can do about that.
I was surprised that the "no name" battery (71Ah) was a few kilograms (felt) lighter than the Moll battery (70Ah) | .
Exactly the same thing happened to me or my "Moll", see: /viewtopic.php?t=26933.
The weight is correct because the quality and performance of a lead-acid battery depend on the amount of lead it contains, not the plastic casing.
Best regards from Munich!
Translated on 21-07-2026, 6:51.
Benni Blaumann
27-02-2013, 14:08 Subject: |
cumminsracer wrote: |
Another observation: I occasionally charged the battery, and more frequently towards the end, using an electric charger (a Cetek clone).
It's suspiciously common for the batteries to fail shortly after purchase. I'm already on my third or fourth one.
Coincidence? It sounds illogical at first. |
"Sorry, I missed that."
Based on my experience, I suspect that the batteries eventually release any sediment they have accumulated during charging with a battery charger (or during a subsequent attempt to start), and at some point, one of the cells becomes faulty, sealing the battery's fate.
I suspect this can be prevented by regularly connecting the charger and forcing a full charge. Furthermore, in my opinion, there are few to no cars that will fully charge the battery with a driving range of up to 25 km per trip.
Another hypothesis could be that isolated sulfate crystals have a stabilizing effect on the remaining structure of the battery and its fine (active) crystals, thereby reducing the formation of sludge. However, this is just a random thought I had.
I decided to go with the cheaper battery because I doubt that the extra cost versus the lifespan of a brand-name battery is worth it. And replacing it is quick anyway. We're talking about the value of almost a full tank of gas, which isn't much.
Translated on 21-07-2026, 6:54.
cumminsracer Blaumann
27-02-2013, 16:05 Subject: |
Here's a small update:
As expected, there was not only loud laughter (from the 19-month-old), but also a fancy, sparkling battery tester that confirmed my dead Varta battery (95Ah 800A) had only 57% power and 580A. According to the printout, "Battery defective."
The battery stayed there for testing, and they provided a "loaner" battery for that purpose.
I immediately connected the Varta starter battery (71Ah, 740A) to that so-called tester, and it showed 95% and 880A, indicating "battery OK"... which says a lot about the accuracy of that "measuring device."
Now I have the loan battery and I'm quite satisfied with it for now... but I will still go back to return it and get my broken one fixed.
@ Martin : Great idea! I just ordered one of those voltage indicators myself.
By the way, does anyone know where to buy a great, standardized, blue, 5-pin "EU electric car charging cable"? Here in Berlin, there are now parking spaces in prime locations that offer "free parking for electric cars" everywhere... Occasionally, you can park for free and meanwhile pamper the battery with a CTEK charger... all that separates you from it is the right cable.
It came to mind again when I saw your wonderful picture.
The clone was connected to a different new battery again, and the voltage across its terminals increased and then stabilized at a constant 13.2V.
What else can be measured? / How else can we measure things?
The T4 has started so far... my skepticism about Cetek is diminishing, diminishing, diminishing...
Translated on 21-07-2026, 6:57.
27-02-2013, 18:58 Subject: |
I can't even find any information about what the plug looks like.
It's all just empty talk about needing to reach an agreement or having already reached one.
This is at least "standard"  .
| Description: |
| File size: |
176.34 KB |
| Viewed: |
1213 times |
![ahk_to_iphoneoagz[1].jpg](download.php?id=7798)
Translated on 21-07-2026, 7:00.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
27-02-2013, 21:45 Subject: |
dieselmartin wrote: | I can't even find any information about what the plug looks like.
This is at least "standard"  | .
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 21-07-2026, 7:01.
Profile PM Email Garage |
matthiasTDI96 Profi-Schrauber
28-02-2013, 7:02 Subject: |
At Google, the plug can be found under "Mennekes," which is one of the manufacturers. I'm not trying to do any kind of promotional advertising. So far, the brand name from our wonderful Sauerland region has been on every plug I've seen, and thanks to RWE being our office neighbor, we have them everywhere  .
Profile PM Garage |
28-02-2013, 9:07 Subject: |
He's currently working on an Opel Ampera.
Translated on 21-07-2026, 7:02.
repro21 Guest
15-10-2013, 19:50 Subject: |
Edit Autoservice: Here, German spelling rules apply!!!! Please correct it or the post will be deleted.
Edit2: Post deleted! Please read the forum rules!
Translated on 21-07-2026, 7:03.
