Öl im Zahnriementrieb - MKB ABS (Gelöst) | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
pax
Avatar-pax
2000 Volkswagen Passat
Post20-10-2013, 0:43    Subject: Quote
Now it's running again. Apparently, I had made the mistake of marking the OT (Top Dead Center) crankshaft position with a screw in the pulley hole – I thought it was at the top and on the vertical axis. After that, I adjusted everything, but it seems I got it completely wrong.
Okay, I've now aligned the crankshaft to the timing mark on the flywheel. There are two notches there, and the slightly larger one is labeled "0". I initially assumed this was the top dead center (TDC) mark. However, I couldn't get that mark to align perfectly with the pointer while also aligning the camshaft TDC directly with its corresponding pointer. What was particularly frustrating was that when tightening the timing belt, either the crankshaft or the camshaft would shift position. However, even if you initially adjusted everything slightly out of alignment before tightening it, there was always approximately a half-tooth offset between the camshaft gear and the crankshaft timing mark.
When checking the ignition timing, the setting should be 6° before top dead center (BTDC). However, I'm not sure how to adjust it. In the distributor, there's a large notch with a drawn arrow, which suggests that you should align with that. But since there's a "0" marked on it, and the small notch might be approximately 6° away, I assumed that you need to adjust to that instead? I took the car for a short test drive with both settings, and it actually ran really well in both cases. How would it have been done correctly?
Regarding the oil issue: I also removed the camshaft gear again. It was slightly oily again, but only in the outer areas. There was nothing on the spokes, and I couldn't find anything on the camshaft itself either. There was also nothing to be found under the valve cover gasket in that area. At the moment, I have no idea where the oil is coming from. During today's test runs, the camshaft gear also remained dry icon_question.gif.
Bye.
peace
Post20-10-2013, 1:05    Subject: Quote
If I remember correctly, the notch should be the timing mark.
I would leave the Simmering alone for a while, or at least observe it.
With a little luck, it will break in and become leak-proof.
pax
Avatar-pax
Post20-10-2013, 11:19    Subject: Quote
Autoservice wrote:
The notch should be the timing mark
. Is it the large notch labeled with "0" or the smaller notch?
How else can you determine if the ignition is "correctly" adjusted? Currently, there are no warning signs, it has power, and it's not misfiring. The driver needs to test the fuel consumption. However, as I mentioned before, it was the same when set to both notches.
After driving 30km home last night, the new oil hasn't been added to the CVT transmission yet.
Bye.
peace
Post20-10-2013, 11:35    Subject: Quote
pax wrote:
The large notch labeled with "0" or the smaller notch?
The small notch is the ignition timing mark... the other one is the top dead center (TDC) mark.
That's how it always was with the old 827 model, which had an intermediate shaft.
When adjusting the ignition timing, the DLS (Dynamic Load Sensing) must be deactivated (if present) to ensure the correct adjustment. Otherwise, the supposedly marked location might "disappear" or become unreliable.
pax
Avatar-pax
Post20-10-2013, 11:43    Subject: Quote
Bertil wrote:
The small notch is the ignition timing mark... the other one is the TDC (Top Dead Center) mark.
Okay, that's how I have it set up right now.
Bertil wrote:
When adjusting the ignition timing, the DLS must be deactivated
. I have no idea what that is, but I put the engine into the basic settings mode using VCDS before making any adjustments.
Oh, the instructions for the ignition tester said to clip the probe onto the cable from the first spark plug - but that didn't work. According to RLF, the connection to the ignition coil was made as described.
Bye.
peace
Post20-10-2013, 12:53    Subject: Quote
So, the default setting mode in "Old-fashioned".... icon_lol.gif .... Edit: but the DLS was only available up to the MonoJetronic. In the MonoMotronic system, everything was controlled via the fuel injection system.
pax
Avatar-pax
Post20-10-2013, 13:24    Subject: Quote
Just to be thorough - does anyone have any information about MWB 0 in the MSG? There are integer values listed, and none of them are labeled.
Bye.
peace
Post20-10-2013, 15:24    Subject: Quote
Thank you for the feedback icon_wink.gif.
Can anyone say anything about the MWB 0 in the MSG?
If everything is okay, let me know so we can close this.
No new posts Doku Lupo 6X1 MJ 2000 - Howling noises from timing belt d... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALH timing belt drive, oily Diesel Engine Technology
No new posts Timing Belt Audi AAT: Old vs. New Differences Diesel Engine Technology
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Engine Diagnostics: 1.6D/TD Solutions Diesel Engine Technology
