servusssss Blaumann
Joined: 11/14/2006 Posts: 159 Karma: +12 / -0 Location: Vlbg
19-09-2013, 12:46 Subject: |
Hello everyone,
A quick update. First of all, thank you for the tips, especially to Autoservice!
The engine is now starting normally. The cause was a loose ground cable connected to the MSG (Main System Module), which was located behind the coolant reservoir.
Now, the car is still having problems with the turbocharger boost pressure. The boost pressure is exceeding the limit (maximum pressure exceeds 2600 mbar at 3200 RPM), and we had to replace the wastegate control valve.
Now, the question is, is there a "default setting" for this?
I couldn't find that information in VCDS.
Thank you very much for your efforts!
Best regards.
P.S.: If needed or desired, more logs can be provided.
Translated on 27-09-2026, 12:21.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
19-09-2013, 13:09 Subject: |
Check this out:
Okay, I'm ready. Please provide the German text you want me to translate. LG, Onkel BM
Translated on 27-09-2026, 12:22.
servusssss Blaumann
19-10-2013, 18:28 Subject: |
Hello everyone,
Here's the solution to the problem described above.
There are several different control units for the turbos in the BKN.
Of course, it was incorrectly installed for the turbocharger that was fitted.
After replacing the control unit, everything works.
SG Christian.
Translated on 27-09-2026, 12:23.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
23-10-2013, 13:38 Subject: |
Thank you for the feedback!
Profile PM WWW Garage |
