Unfortunately, the Polo does not have a comfort control unit
Is there a way to disable the comfort function?
Vehicle Identification Number: License Plate: POLO 6N2
Mileage: 47180 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: XX (6N - VW Polo (1995 > 2002))
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
Vehicle Identification Number: XXXXXXXXXXXXXXXXX
Mileage: 47180 km
Address 01: Engine Control Unit
Label file: None
Part number: 030 906 032 CK
Component: ME7.5.10 3628
Coding: 00031
Operating number: WSC 31414
VCID: 55A5D1ADAF2ECAB6975-5148
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics
Label file: RKS\6X0-907-379.lbl
Part number: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Encoding: 05603
VCID: 43811FF551BA4406C91-4B14
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 A
Part: 2P AIRBAG VW5 03 0006
Encoding: 12880
VCID: 3565712D0F6EEAB6775-5148
2 error codes found:
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
01280 - Passenger airbag deactivated.
35-00 - -
Address 17: Control unit insert
Label file: RKS\6N0-920-xxx-17.lbl
Part number: 6N0 920 804 E.
Component: KOMBIINSTRUMENT BOO V12
Encoding: 00141
Operating number: WSC 00006
VCID: 306B4039F00CCF9E243-5164
"One error found:"
01039 - Coolant temperature sensor (G2).
64-10 - Currently not verifiable - Sporadic.
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway <-> CAN.
Encoding: 00022
VCID: F0EB0039B08C0F9EE43-5164
Address 25: Immobilizer
Label file: RKS\6X0-953-257.lbl
Part number: 6X0 953 257.
Component: IMMO 0008
Encoding: 00001
Operating number: WSC 00000
VCID: FDF5290DF7DE72F67F5-4B14
XXXXXXXXXXXXXXXXX VWZ1Z0A1497534
End.
