Clogged Diesel Filter?
saxi
Post10-06-2002, 22:21    Subject: Clogged Diesel Filter? Quote
Hello!
wie merkt man eigentlich einen verstopften dieselfilter? hat man weniger leistung oder läuft das ding dann nicht mehr rund und stockt im oberen drehzahlbereich?
eike
Post11-06-2002, 9:08    Subject: Re: Clogged Diesel Filter? {SUBJECT} {BODY} Quote
He becomes cranky in the middle range of engine speed and no longer reaches its maximum speed. Then, it sucks air through a seal of the T-piece attached to the diesel filter. You can clearly see the air traveling through the transparent line to the pump. However, there is almost always some air present there. If you're giving it gas and it's almost just air in it, then it's probably time for a new filter.
Greetings
Eike
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Bleed Diesel Filter: How To & Why Diesel Engine Technology
No new posts new diesel filters Diesel Engine Technology
No new posts Wood chips in diesel filter - TPI? Diesel Engine Technology
No new posts Diesel Filter CFFB - Buy Online Now! Diesel Engine Technology
