chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
06-12-2013, 17:06 Subject: 1.2L Polo 3-cylinder cylinder head cover |
Hello!
I'm currently doing a timing belt replacement on a 2006 Volkswagen Polo 1.2.
I'm currently re-sealing the cylinder head cover. According to VW, you should use the green sealant D154 103 A1. I applied the sealant to the cover, but after about 24 hours, it's still liquid.
How long does it need to cure? A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:22.
Herbert Profi-Schrauber
06-12-2013, 18:38 Subject: 1.2L Polo 3-cylinder cylinder head cover |
Hi there,
"24 hours should definitely be enough. Could it be too cold where you are, or is the sealant past its expiration date? Or are only the parts that have been exposed to air still liquid?"
Best regards.
Herbert. Horch A4 8K CJCD
Translated on 18-07-2026, 12:23.
chriskross Blaumann
06-12-2013, 18:42 Subject: 1.2L Polo 3-cylinder cylinder head cover |
It's probably around 10-15 degrees Celsius here.
The packaging indicates that it is usable until 07/14.
I'll wait until Monday; I hope it will be dry then.
Do you also use the green sealant to seal the control unit housing? A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:24.
06-12-2013, 18:49 Subject: 1.2L Polo 3-cylinder cylinder head cover |
The sealant should be suitable. It cures on metal when exposed to air, i.e., after assembly. Perhaps only the excess material is still liquid?
Translated on 18-07-2026, 12:25.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
06-12-2013, 19:24 Subject: 1.2L Polo 3-cylinder cylinder head cover |
Quote: | | The sealant should be suitable. It cures on metal when exposed to air, i.e., after assembly. Perhaps only the residue is still liquid? |
Absolutely, the vehicle is ready to operate immediately after assembly. It only becomes hard on the outside after days or weeks. LG, Onkel BM
chriskross Blaumann
06-12-2013, 20:18 Subject: 1.2L Polo 3-cylinder cylinder head cover |
Yes, exactly. I mean the residual sealant, which is still liquid.
I'm relieved to hear that; it probably explains the price of a tube!
Thank you!! A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:26.
Styrian
07-12-2013, 11:03 Subject: 1.2L Polo 3-cylinder cylinder head cover |
"...just for reference: How much does a tube cost? How much product is inside? And is it the same as the Elring AFD 2018 (which is red)? That one is listed as an OEM part."
...somehow, I found the older seals more appealing...just my opinion...
Best regards, Styrian.
Translated on 18-07-2026, 12:27.
chriskross Blaumann
07-12-2013, 11:41 Subject: 1.2L Polo 3-cylinder cylinder head cover |
The tube containing 100g costs €50.
According to VW, there is a different sealant for the control unit housing, costing €25, which will likely be purple  . A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:28.
Styrian
09-12-2013, 11:39 Subject: 1.2L Polo 3-cylinder cylinder head cover |
...where money can be made...at least, thank you for the information...
