Kraftstoffilter wechseln Motorkennbuchstabe CAAB | Posts 16+
Go to page: Previous  1, 2
Post25-01-2014, 22:13    Subject: Quote
Please provide a list of the diagnostic data points available from the engine control unit (ECU) for actuator diagnosis.
Ideally, I'd like to do it once selectively and once comprehensively.
I claim that your assertion that it's not possible is nonsense, and you have your head in the clouds. icon_wink.gif
PS: What you're referring to are actuators, not "control units." It concerns the actuators that the engine control unit can control.
chli1976
Post25-01-2014, 23:50    Subject: Quote
I've experienced this issue multiple times with the CRs.
Here are some pictures. Actuator diagnosis is not working with VCDS.
http://www.vagcomforum.de/index.php?showtopic=21188&hl=
VCDS
stolley
Karma: +38 / -1   Thank you, like it!
Post27-01-2014, 8:24    Subject: Quote
Good morning, Rainer!
As my colleague mentioned earlier, it is not possible to activate the fuel pump using the actuator diagnostics function on this vehicle.
Instead, it works on the T5 model via STG 01, basic settings, block 035.
You can run the pump for 30 seconds at a time there.
So far, so good!
What really annoyed me yesterday was the fact that the engine control unit kept failing (at the latest, after the pump had been running for 10 seconds)!
Unfortunately, I had to "break in" my new car.
What could be the reason for that? By the way, the STG (Steuergerät) has also been discontinued for other functions, including in my Polo 9N3!
It's strange because I feel like it happened much less frequently after the engine had warmed up somewhat!
Could it be that the engine control unit "freezes" at temperatures around freezing point?
Best regards, Volker.
Post27-01-2014, 10:56    Subject: Quote
Very quirky... it works with my boxes, but I've never needed it because the fuel pump runs for a few seconds when I turn on the ignition anyway. "Ignition ON/WAIT/OFF/ON..." has never caused me any problems.
No, but have you ever checked your onboard voltage?
stolley
Post27-01-2014, 18:16    Subject: Quote
That's quite peculiar... it works with my boxes, but I've never needed it because the fuel pump runs for a few seconds when the ignition is turned on anyway. "Ignition ON/WAIT/OFF/ON..." has never caused me any problems.
Best regards, Rainer
Hello Rainer!
I definitely repeated that 10-second pump exercise about 8 times. Despite that, I had to replace the filter - perhaps because of the perceived 5-liter capacity of the filter in the T5.... icon_wink.gif
The on-board voltage was actually completely gone! Then I charged it, and finally, I used the fully charged second battery to jump-start the car: it was always the same result.
And the same goes for the Polo...
Volker.
No new posts Boost behavior of VAG TDI engines, engine code AHF Technical Articles
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts T5 Engine Jerking: CAAB Code Troubleshooting Diesel Engine Technology
No new posts Kraftstoffilter Diesel Engine Technology
No new posts Diesel pre-heating / Fuel filter Diesel Engine Technology
No new posts Fuel Filter: Starting Problems? (ATU) Diesel Engine Technology
