Polo6R - GRA Activation - Schaltplan/Pin Diagram needed
gotboost
Post28-01-2014, 17:31    Subject: Polo6R - GRA Activation - Schaltplan/Pin Diagram needed Quote
Dear Hobbyist,
I am looking for the correct pin configuration for the KUFATEC GRA retrofit.
The GRA has already been unlocked on my Polo, but the following error appears in the on-board diagnostic system:
Vehicle Type: 6R (6N0), Year of Manufacture: 7/2010, Power: 51kw, Voltage: 12.16V, Motor: CGP
Scan: 01 03 08 09 15 17 19 25 44 56
Vehicle Identification Number: WVWZZZ6RZAY268239
01-Engine Electronics -- Status: OK. 0000
03-Brake Electronics -- Status: OK 0000
04-Steering Angle Sensor -- Status: OK 0000
08-Climate/Heating System -- Status: OK 0000
09-Main Electrical System -- Status: Error 0010
15-Airbag -- Status: OK 0000
17-Switch Panel Insert -- Status: OK 0000
19-Diagnosis Interface -- Status: OK 0000
25-Way Ignition Switch -- Status: OK 0000
44-Steering Aid -- Status: OK 0000
56-Radio -- Status: OK 0000
2 error codes found:
00532 - Supply Voltage
011 - Interruption - Sporadic
Freeze Frame:
Error Status: 00101011
Error Priority: 2
Error Frequency: 1
Loss Count: 154
Time: 0
00895 - GRA/ADR Control Panel (E45)
008 - Unlikely Signal - Sporadically
Freeze Frame:
Error Status: 00101000
Error Priority: 3
Error Frequency: 2
Number of Losses: 150
Mileage: 62860 km
Time: 0
Date: 2042.14.23
Time: 08:54:46
Seems like there's a wiring issue. I have checked the wiring twice - now I need a wiring diagram or pinout, as I suspect that the wiring labels are incorrect...
I am requesting assistance and hope that someone here has something useful to offer.
I have the latest version of VCDS, should there be another diagnostic possibility to narrow down the error?
Thank you very much!
Gotboost!
Nur daquer bist wer.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pinout diagram for A4 speedometer, manufactured in 1996, ... On-Board Diagnostics (OBD)
No new posts T4 Wiring Diagram: Find Your Schematic Now Diesel Engine Technology
No new posts Audi B6 AWX Wiring Diagram: Find Yours Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Fan Control Wiring Diagram: Find Yours Now! Transmission, Chassis, Body & Interior
