Polo 6R: Sensor Data Not Available
Glatze
Post28-03-2014, 20:45    Subject: Polo 6R: Sensor Data Not Available Quote
Hello.
I want to check the DPF loading status in a VW Polo 1.6 TDI, manufactured in 2009, using the engine control unit (ECU) address 01 and measuring block 108.
Aber bei meinem VCDS ist der Button fĂźr die MessertblĂścke grau hinterlegt! Soft is current!
Does anyone have any ideas?
Translated on 25-10-2026, 0:18.
Post28-03-2014, 22:05    Subject: Polo 6R: Sensor Data Not Available Quote
Keyword: Extended measurements - attempted?
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 25-10-2026, 0:19.
Post28-03-2014, 22:28    Subject: Polo 6R: Sensor Data Not Available Quote
Does anyone have an idea
Okay, go to Start -> Programs -> VCDS-RKS -> Manual.
Or online, Chapter 9:
http://shop.dieselschrauber.de/download/VCDS-Handbuch.pdf
Glatze
Post30-03-2014, 17:57    Subject: Polo 6R: Sensor Data Not Available Quote
Okay, thank you. I found it there.
Are these values okay at 68,000 km?
85% short distances.
Address 01: Engine Control Module (03L 906 023 E)
233 Particle filter; Oil ash content - MASS_ASH_PF 17.4568957 g
234 Particle filter; Oil ash volume - MASS_ASH_PF 17.4568957 g
235 Particle filter; calculated soot mass - MASS_SOOT_SIM_PF 13.00 g
236 Particle filter; Soot mass measured - MASS_SOOT_PHY_PF 0.30 g
237 Particle filter; Time since last regeneration - T_WOUT_RGN 9170.70 s
Translated on 25-10-2026, 0:20.
Post31-03-2014, 11:42    Subject: Polo 6R: Sensor Data Not Available Quote
Are the values okay at 68,000 km?
It looks normal. At 200,000 km, there should be approximately 55 grams of ash in the filter.
Translated on 25-10-2026, 0:22.
Glatze
Post31-03-2014, 11:46    Subject: Polo 6R: Sensor Data Not Available Quote
Okay, thank you.
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI Parts: AFB/AKN - Not Available Diesel Engine Technology
No new posts Start/Stop is unavailable, what does the measurement bloc... On-Board Diagnostics (OBD)
No new posts VCDS 16.8.0: Channels Unavailable After Update On-Board Diagnostics (OBD)
No new posts ECU Data: Access Issues & Troubleshooting On-Board Diagnostics (OBD)
