Golf 5 1.6 FSI Fuel Problems in Heat
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post04-07-2014, 15:29    Subject: Golf 5 1.6 FSI Fuel Problems in Heat Quote
I have a customer's vehicle here and I'm not able to pinpoint the source of the problem.
Golf 5 1.6 FSI (Engine Code: wird nachgereicht) has problems while driving in hot weather. It starts with stuttering and can even cause the vehicle to stall and not start again.
That evening, as it cooled down, things improved somewhat, but there was still a slight stammering.
Error Storage:
Wednesday, 02, July, 2014, 13:43:00:58542
VCDS Version: RKS 12.12.0
Address 01: Engine Electronics Label file: RKS\06A-906-033-BGU.lbl
ECU Part Number: 06A 906 033 CA
Part and/or Version: SIMOS 71 1.6l 2VG 9862
Encoding: 0000071
Operating Number: WSC 79235 146 83762
VCID: 60C996A8B3A70D1EF43-8035
1 Error found:
16555 - Fuel Measurement System (Bank 1)
P0171 - 006 - Lean System - Sporadisch
Readiness: 0000 0000
I have previously tested the fuel tank vent valve, and it operates and allows air to pass through even when the engine is running.
Activated carbon filter is not clogged, but the first one at 120,000 km is likely still functional.
All pipes up to the tank have been checked and blown through with compressed air.
On the tank itself, I checked 2 more lines for pressure and vacuum, and I didn't find any abnormalities.
If it's warm and the fuel tank has been recently filled, you'll hear a loud "hissing" sound when opening the fuel cap. I suspect that air is flowing in and not escaping.
The fuel tank ventilation valve should suck up the fuel vapors through the activated carbon filter due to the vacuum behind the DK. "Does this not also create a vacuum in the tank?"
How exactly is this being ventilated?
Maybe one of you can offer some advice.
Thank you.
No new posts Doku Golf 5, Probleme mit Heckklappe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J1587, Probleme mit Haldex-STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problem in hot weather Diesel Engine Technology
No new posts Motorelektronik setzt aus bei Hitze Diesel Engine Technology
No new posts French fry oil as fuel... Diesel Engine Technology
No new posts AHF TDI: O-Ringe am Dreiwegeventil Kraftstoff-Filter Diesel Engine Technology
